I have my PC hooked up
To my Maya44 thru the USB connect
Maya44 connected to my mixer the the Analog Out 1234 using cables to my mixer
DXM06 at it's Line 1 and Line 2 and yes the switchs are both moved to the LINE
Using monitor speakers, i have two speakers being used
There is no other things connected like cd or turntables
Now i am having a problem when I pull up Virtual DJ and go to CONFIG I am not sure the correct settings
Inputs ? None???
Outputs ? Single outputs??
Sound Card? Maya44 USB??
I did get it going but only one speaker
Any help would sure be great help
Thanks DJzerry
Inputs ? None???
Thanks DJzerry
geposted Tue 10 May 11 @ 10:43 pm
Your outputs should be "exturnal mixer".
Try that and let us know
Huey
Huey
geposted Tue 10 May 11 @ 10:48 pm
I tried it and got an error message
Error in the ASIO sound driver. Not enough channels
geposted Tue 10 May 11 @ 10:55 pm
Then
It said
Error in the ASIO sound driver. Your sound card is probably not connected or the settings are incorrect
geposted Tue 10 May 11 @ 10:57 pm
Ok give me a minute while I dig this card out and try it. And just so were straight your not using any timecodes or MIDI controller?? You just want the sound to come of of the card and into the mixer?
Huey
Huey
geposted Tue 10 May 11 @ 11:02 pm
Yes no time codes, simply two monitor speakers coming out of jacks thru the mixer
geposted Tue 10 May 11 @ 11:04 pm
The correct settings should be:
Inputs: None
Outputs: External Mixer
Sound card: ASIO -> Choose Maya44 in drop-down list.
If this fails, re-install the drivers for the Maya44 and make sure that you always plug it into the SAME USB port.
Inputs: None
geposted Wed 11 May 11 @ 8:38 am
I do have the settings at
Inputs: None
I did re-install my driver for the Maya44 USB and left it in the one same USB port
Still stuck?
Inputs: None
Still stuck?
geposted Wed 11 May 11 @ 3:17 pm
I am still stuck
Any help please
Any help please
geposted Wed 11 May 11 @ 10:01 pm
Posting in multiple threads is not going to help you more. Please stick to one thread.
you have an answer here https://virtualdj.com/forums/147583/Hardware_Technical_Support/Maya44_USB_Reinstall_Help.html
geposted Wed 11 May 11 @ 10:26 pm
