Hey, Im running an older mixer with no midi so i cant map to it. I was wondering if there is a working map command to create a button which can swap my time coded vinyl from deck 1 to deck 3 and a button to swap deck 2 to 4. Ive looked allover the forum and seen code for midi mixers and controllers but nothing that works for a keyboard map.
thanks for you time
thanks for you time
geposted Wed 11 May 11 @ 2:39 pm
https://virtualdj.com/forums/135723/Hardware_Technical_Support/Advanced_Mapping_Verbs_Swap_Decks.html
That should work, don't know how it works personally as I have never tried it
geposted Wed 11 May 11 @ 9:59 pm
One button to swap the left timecodes..
deck 1 timecode_active 1 on ? deck 3 timecode_active 1 on & deck 1 timecode_active 1 off : deck 1 timecode_active 1 on & deck 3 timecode_active 1 off
and another one for the rights..
deck 2 timecode_active 2 on ? deck 4 timecode_active 2 on & deck 2 timecode_active 2 off : deck 2 timecode_active 2 on & deck 4 timecode_active 2 off
geposted Wed 11 May 11 @ 10:24 pm
Ah mate you are a absolute legend, thanks massively
geposted Thu 12 May 11 @ 5:05 am
