Forum: VirtualDJ Plugins
Topic: Karoke Effect Freezes VDJ
Ok i am starting to get into teh karoke part of djing, but I am having a little problem. Whenever i enable the video plugin and pick karoke, its freezes VDJ am i doing something wrong? Sorry for the stupid question.... and how do you get video to start playing, do i have to make my own?
geposted Fri 13 May 11 @ 10:21 pm
Here are instructions from the user manual, see if it helps...
Good Luck,
Joey...
Make sure your Karaoke Zip files are compressed no more then a "5" or they will make VDJ work harder to open and might even error out, if you use this program to recompress your karaoke files or at least a sample folder to see if this will fix the problem you're experiencing then you can continue this process in your main folder, the MP3+G Toolz 4 program is free, here's the link. http://www.activeaspsoftware.net/default.aspx?p=home
Good Luck,
Joey...
