Once the visible playlist area has been filled with songs, adding additional songs puts them out of sight off the bottom of the screen. It would be helpful if the list scrolled to the bottom of the list when adding additional songs the otherwise would be added to the bottom of the list.
geposted Sun 15 May 11 @ 1:33 pm
You mean to automatically scroll the window list at the bottom as you add files so they can be seen easily, yeah this would be nice to have, you would save the extra step of manually doing this before you add additional files to make sure you are actually adding to the bottom and not in between the previous batch...
geposted Sun 15 May 11 @ 4:34 pm
in the meantime you can assign a keyboard or midi button as ..
playlist_add
this will add the selected song at the end of your playlist.
playlist_add
geposted Tue 17 May 11 @ 10:30 pm
Perfect, Thanks...
geposted Wed 18 May 11 @ 4:02 am
