Virtual DJ is great for karaoke, except the quality of the key change algorithm leaves an enormous amount to be desired. Standard karaoke machines allow + or - 6 semitones, and the audio quality is impeccable - ie the quality of the sound doesn't degrade - unlike the key changer in VDJ where even a 1 semitone change sounds pretty awful.
How about an update - please!!
geposted Sun 22 May 11 @ 8:00 am
Are you using the latest VirtualDJ v7 with Advanced Stretching selected in CONFIG -> Performances
If you are using the default Fast algorithm, then the quality will not be as good.
Also, there is a new advanced master tempo in VirtualDJ v7, so if you are running an older version such as v6, the advanced quality will not be as good.
geposted Sun 22 May 11 @ 1:56 pm
