Hello Everyone,
Is it possible to add the pitch display on VDJ original 4 decks? On the 6 decks, it is visible above the pitch level when I adjust the % pitch.
Is space the issue?
Thank you for your assistance.
Is space the issue?
geposted Mon 23 May 11 @ 8:05 am
I am not sure what you mean? the pitch display is right above the track playing to the right of center.
Is this what you are asking about in the four deck?
geposted Fri 27 May 11 @ 2:31 pm
You could use the four deck skin which will display all info on four decks, as in the two main decks, if you need to display on the six deck skin, swap mains, "A" & "B" to get the info displayed....
geposted Fri 27 May 11 @ 3:52 pm
Sorry for the delay...Typhoon decided to come our way.
Whatsurbucket: Yes there is a pitch, but the pitch %, isn't present on a 4-deck. It is on a 6-deck, right above the slider. I set up a mapper with shift key to alternate shift % & use the 4-deck instead of the 6-deck- It's not going to kill me...
JoeyKJ: Thanks, I'm aware I can use the 6-deck. I wasn't sure if I was missing something on the 4-deck. Sounds like my only solution if I use the 4 deck is use the pitch on an empty deck, adjust the pithc %, & use the pitch level to see where I'm at.
It's not a show stopper. Thank you.
FLeX
FLeX
geposted Wed 01 Jun 11 @ 8:07 am
That's a pretty good idea Flex.
geposted Wed 08 Jun 11 @ 1:38 pm
