Hey guys,
I'm using virtual dj for broadcasting, im doing a lot of live sets with it. I've just installed the vdj 7, and wanted to set up the mic, the headphones and of course the master... I was a bit surprised when i realized that there is no "master + mic" anymore..."okay" i said..it cant be so difficult to set it up as i did in the older versions...but it WAS!!! I didn't manage to have my voice in the microphone and also the music at the same time... I saw the same problem at soo many topics in the forum but I realized that everybody's talking about ASIO, and Hercules, and soo many kinds of controllers and sound cards, so i couldn't find any useful tip witch includes my settings.
What do i mean?
I dont have any controllers for vdj... I dont have asio driver..just a built-in soundcard (realtek ac'97). I used to set it like this (in the older versions):
Sound Setup- (outputs) Headphones- (sound card) 4.1 card... then i plugged the headphones to the green jack, the speakers to the blue one, and selected in the record settings "master+mic" and i did not have to do anything else with the mic at all. Now i cant work with these settings.. In advanced config if i choose input microphone it has got only some kind of noise...but not my VOICE, only the music works during recording...
If i choose record loopback, i have my own voice on the recording (bad quality) but there is NO music....
I have got no any ideas about it...I dont want to change vdj 7 to an older one because I need at least 3 decks.. PLS SOMEBODY HELP ME...
And before answer it is important: I haven't got asio, i haven't got controllers...just my pc, my mic, my headphones, and the software..so please try to give an answer witch works with only one built in soundcard..because i haven't got anything else...
What do i mean?
geposted Tue 24 May 11 @ 1:24 pm
Here's your other thread, no need to start multiple threads on the same subject, https://virtualdj.com/forums/148187/PC_Version_Technical_Support/HELP_ME_PLS____Recording_microphone_and_master__DOES_NOT_WORK____.html
Good luck
Huey
Try this thread aswell, https://virtualdj.com/forums/135686/PC_Version_Technical_Support/VD7__and_voice_.html
Good luck
Huey
geposted Tue 24 May 11 @ 2:06 pm
