Hi,
your microphone plugin is very good. I've been looking for something like this for a long long time.
But one question:
Can you make the microphone level change to zero if you deactivate the plugin, and if activated the level up to a value wich you set with the slider ?
This would be very nice because the microphone is still active and you have to switch off the mic itself.
Sorry about my bad english but i hope you understand what i mean.
greetings
Janosch
But one question:
greetings
Janosch
geposted Thu 28 Aug 03 @ 5:11 pm
I understand and I think I will make a new version soon.
This new version will reduce the volume of the two deck by moving there sliders or the master volume (when the tolk-over is on of course) and not only the one on which the plug_in is activated.
So, I will take a look at what you ask.
Neverstheless, when you stop the plug_in, it should mute your microphone (if available on your sound card)
In any case, thank you for this feedback. ;)
Kaleo
Kaleo
geposted Thu 28 Aug 03 @ 5:26 pm
Kaleo you're great. Thank you for the quick answer.
greetings
Janosch
greetings
Janosch
geposted Fri 29 Aug 03 @ 12:19 am
kaleo is the new Plugin GOD :)
geposted Fri 29 Aug 03 @ 1:00 am
DJ Walkers:
Iff oonly Iiii couulddd... tuduuu dum
(I don't remember who was the singer)
geposted Fri 29 Aug 03 @ 8:24 am
Thanx kkaleo keep good work pal
geposted Fri 29 Aug 03 @ 12:55 pm
Janosch:
As I said, the plug_in should mute the microphone output when you stop it. Maybe it's not working on some sound cards so I add what you asked :)
And you can use the plug_in on one desk, the talk-over will work on the wav-out volume so on the whole VDJ sound but not on microphone.
You will be able to test it as soon as Microphone Control v1.1 will be available on the add-ons page.
Fell free to tell me that you think about it :)
geposted Mon 01 Sep 03 @ 8:45 pm
Thanks. That's what i need.
I will test it and tell you how it works.
Janosch
Janosch
geposted Tue 02 Sep 03 @ 12:39 am
Oups, a little strange bug. Thanks to Dams, I will correct this.
Wait a little more, sorry :)
geposted Tue 02 Sep 03 @ 12:52 pm
