I use the Virtual folders and sub Virtual folders in Virtual Folders is there a way to make a right click on a Virtual Folder to Alphabetize the sub folders, then to lock it in place so it won't change?
geposted Sat 28 May 11 @ 10:35 pm
You will have to manually do it, there is no option to do that.
The lock in place feature, well it's also not available, but a good one.
geposted Sun 29 May 11 @ 7:57 am
the only problem I have is I have over 150 sub folders sorted by name...
geposted Sun 29 May 11 @ 8:02 pm
Try filter folders or break down the 150 folders into Major groups, say 10 major, and 15 sub's for each....makes it more manageable....
Good Luck,
Joey...
Good Luck,
Joey...
geposted Mon 30 May 11 @ 4:15 pm
I believe PCDJ had the folders automaticly sort... I could be wrong it has been awhile since I've used that program... I guess I'll have to make another group of sub folder to break down the massive files of Entertainer's playlist...
geposted Mon 30 May 11 @ 4:30 pm
