when i tried to update got error message that reads Cabinet file .virtual dj.cab is curupt..any help on this
geposted Mon 30 May 11 @ 9:32 pm
Make sure you download the correct file (msi is for windows , pkg is for MACs.) I noticed that you downloaded both of them twice. Does the installation files downloads completely ? What is the filesize you receive? Choose to save the installation file and check filesize.
geposted Mon 30 May 11 @ 10:21 pm
The windows version size is 31.2 MB (32,776,848 bytes).i run pc and mac havent tried mac setup yet but tried to setup on two different pcs same error.
both were running previous version with no problem.
geposted Tue 31 May 11 @ 12:51 pm
Does it work now?
If not, please deinstall/delete "ALL" VDJ versions from your computer
Download and install only the version from your download center again.
https://virtualdj.com/download/updates.html
Install VDJ as a user with admin rights.
Open VDJ as the same user, still with admin rights.
geposted Wed 01 Jun 11 @ 9:16 am
The cabinet file 'virtualdj.cab'required for this installation is corrupt and cannot be use .this coul indicate a network error , an error reading from CD-ROM,or a problem with this package. please help me for this .
geposted Tue 30 Jul 13 @ 10:32 am
which version of Virtualdj are you installing?
geposted Wed 31 Jul 13 @ 2:10 am
seems a RAM problem for me, usually CRC fails when RAM memory had problems, , try to run a memtest.
geposted Wed 31 Jul 13 @ 9:34 am
I have the same Problem.
Please Help me.
Please Help me.
geposted Sat 31 Jan 15 @ 6:52 am
why is my virtualdj.cab corrupt ???can any one explain why or can i get another cabinet ???
geposted Tue 22 Mar 16 @ 10:03 am
