By default, www.virtualdj.com is the stream url, but users would like the option to edit that and put in their own stream url for example: External link removed
geposted Sun 05 Jun 11 @ 10:25 am
This feature already exists. You need to manually adjust your settings after checking the Broadcast to a radio server section of the broadcast config area.
geposted Sun 05 Jun 11 @ 7:07 pm
Really? We've been trying to change the www.virtualdj.com to www.soulcitygrooves.com but this is the only thing you can't change...
geposted Mon 06 Jun 11 @ 5:16 pm
No it doesn't ... if your broadcasting and you look on the info, you'll see www.virtualdj.com .. it doesn't give users the opportunity to change the broadcast url.
geposted Sat 11 Jun 11 @ 9:41 pm
Sorry, the URL cannot be changed at present.
Also, VirtualDJ Home FREE does not support broadcasting anyway: http://www.virtualdj.com/products/comparison.html
geposted Sun 12 Jun 11 @ 1:36 pm
