Newbie qustion...
Just got me DJ2GO, installed on my laptop with the supplied LE version, all working well apart from the 'LOAD A' & 'LOAD B' buttons don't seem to be mapped/working ? can anyone help with this ?
Also, how do I use the controller on another desktop machine with 7 PRO without installing the supplied LE software ?
Many thanks in advance,
geposted Mon 06 Jun 11 @ 1:33 pm
Make sure that you have the latest version of VirtualDJ LE installed - You can download it from https://virtualdj.com/download/updates.html
To work in VirtualDJ Pro, you will need to purchase and install the latest v7.0.4 version otherwise it will not work correctly: https://virtualdj.com/buy/ (You can upgrade at a discount from LE.) If the latest Pro is installed, then there is no need to install LE.
geposted Tue 07 Jun 11 @ 5:40 am
Hello... This question may have been posted and answered already, but I can't find it. Never the less,
I'm new to VDJ and just purchased the DJ2GO and the Numark PHX USB headphones, but can't get any sound in the headphones, let alone getting deck A or B to cue up in the headphones.
Can anyone tell me how to set it up to make this happen? I'm running the LE software that came with it on a macbook pro.
Thanks.
DjMarkEliot
Thanks.
DjMarkEliot
geposted Sat 09 Jul 11 @ 11:18 pm
I have a numark dj2go and one of the jog wheels allow me to scratch while the other changes the pitch of the music.
How can I change the setting to allow me to scratch on both jog wheels?
geposted Tue 07 Aug 12 @ 10:02 pm
Please see our FAQ pages:
https://virtualdj.com/wiki/Vinyl%20mode%20is%20turned%20off.html
geposted Wed 08 Aug 12 @ 4:44 am
how can i get my numark dj2go to work with virtual dj pro 7?
geposted Wed 08 Aug 12 @ 2:20 pm
Purchase a licence and download the latest 7.05b version where it is natively supported.
Keith
Keith
geposted Wed 08 Aug 12 @ 3:16 pm
hi i have numark dg2go butt u dont have software in my laptop can help me send me software for dj2go thanks
geposted Thu 21 Feb 13 @ 4:59 am
If you got a device without the Lite Software it get's delivered with you should return it to the store and ask for a complete pack.
If you bought it without Software or second hand you need our Professional Full version to use it with or any other kind of MIDI featured DJ Software.
Greets, Heiko
Greets, Heiko
geposted Thu 21 Feb 13 @ 5:06 am
To load a track (DJ2GO) you need to press the load button twice.
I have the also purchased this item as a back up. Two questions: 1/ Can I use DJ2GO with Numark Cue 5 (Full Version)? 2/ When I connect my DJIO to VDJ LE (Lite) no external mixer option shows up. Does this mean I cannot separate the signals to two channels?
geposted Tue 09 Jul 13 @ 12:49 pm
No, it's far too old and doesn't natively support it unlike the latest version of the software that has full native support with working LED's.
Please register your Numark Cue serial number to your account and then download the latest version from the Download Center.
VirtualDJ LE/Lite is limited software and does not support this option. It supports master/headphone setup only. Please see: https://virtualdj.com/products/comparison.html
To be able to output the decks separately to the an external DJ mixer, you will need to upgrade to the full VirtualDJ Professional at a discount: https://virtualdj.com/buy/ (Or use the full Numark Cue if you have purchased and registered it as above and updated it to the latest version.)
geposted Tue 09 Jul 13 @ 1:40 pm
ive lost the serial number for the virtual dj le lite (dj2go), is there anyway of getting a new serial number for it?
geposted Fri 10 Jan 14 @ 11:05 am
Please see https://virtualdj.com/forums/151663/General_Discussion/Lost_Serials_-_VirtualDJ_LE_or_any_other_version.html
You can also contact support if you need any further assistance: https://virtualdj.com/contact/
geposted Fri 10 Jan 14 @ 11:34 am
hi, just got my new dj2go but only have a new imac with no ability to put in a cd, where can i download the software from?
geposted Fri 17 Jan 14 @ 12:34 pm
Register the VDJ LE serial number to your account here, then you will be able to download from your download center.
geposted Fri 17 Jan 14 @ 12:49 pm
Dear sir, I have tried to use my DJ2GO tapped on the icon and it asked for my serial number, I know longer have the disc or serial number, could you please help/advise me how I can get it working, or can you send me it please, thank you. E MAIL <removed>@hotmail.co.uk
geposted Mon 10 Nov 14 @ 6:23 am
geposted Mon 10 Nov 14 @ 2:08 pm
Hi GUys
I purchased a ion DJ2GO controller from a friend but he never gave me any cd or anything so every ten minutes VDJ kicks the controller out.
Can you please help me!!1 :(((
geposted Tue 10 Feb 15 @ 2:07 am
You must buy a "controller license" from here -> https://virtualdj.com/buy/
geposted Tue 10 Feb 15 @ 6:35 am
I bought the DJ2Go controller on Amazon and it didn't come with the CD. I was able to download he software but its now asking for a serial number. I've checked everywhere, can anyone please please please tell me where do I find the serial number?
geposted Thu 28 May 15 @ 9:07 pm
