So that VDJ can automatically syncronise tracks which are out of sync due to delay caused by plugins, such as eq/effects plugins.
geposted Mon 06 Jun 11 @ 6:06 pm
You can adjust the audio delay by adjusting the latency in CONFIG -> Performances (Non-ASIO card or Apple Mac) or CONFIG -> Sound Setup -> ASIO Config (ASIO card on PC.)
geposted Tue 07 Jun 11 @ 5:04 am
But how can that help solve the problem of delays caused by plugins on one channel etc? When a CPU intensive plugin is used on one channel and not the other it gives the channel a delay and puts it out of sync when you listen to it.
Also, the delay changes as you change whatever the plugin is doing. So for example, if its a notch ew filter, and you change from say 4 notches / bands to 6, then the delay increases. THere needs to be some one that VDJ knows the delay and can compensate. Im not really sure how it works exactly, but I believe it called latency reporting. THe plugin reports the latency to the host app, which then compensates. Apparently, Ableton supports this.
geposted Wed 08 Jun 11 @ 7:08 pm
