Forum: VirtualDJ Plugins
Topic: unable to use vst plugin
hey all,
so i tried for the first time to use a vst effects pluggin and have failed.
i used the demo version of Turnado by Suga Bytes. The demo version is available as a free download and i was trying it out to see if it was worth buying but i simply cant get it to work at all. if anyone had any ideas do let me know.
http://www.sugar-bytes.com/content/download/demo/index.php?lang=en
i have downloaded and installed the latest direct x and visual c++, i then moved the .dll file into the soundeffects folder of virtual dj. when i open up virtual dj it does show up in the effects list but when i click on it nothing happens the screen where the effects parameters generally are just stays blank! i would really appreciate it if anyone has any ideas as to how to make this work.
thanks in advance!
geposted Tue 14 Jun 11 @ 12:49 am
Some VST's are not compatible, the best advice would be to ask the author for help and give them the free VDJ link and maybe they will help make it happen...
Free VDJ Link..http://www.virtualdj.com/download/free.html
Good Luck,
Joey....
