Hercules Mapper Pack v1.8
Download -> http://www.virtualdj.com/addons/8336/Hercules_Mapper_Pack.html
I made some changes to the default mapper for Virtual DJ v7.0+ with Hercules HDJC(MK1) - MK2 - MP3 - MP3 e2 - MK4 - Steel - RMX- DJ 4Set & 4-Mx.
The ZIP pack mappers that you have downloaded it to unzipped and copy/overwrite in the path:
PC -> C:\Documents and Settings\User Name\My Documents\VirtualDJ\Mappers
MAC -> Documents\VirtualDJ\Mappers
(do it with Virtual DJ closed)
v1.8
- Ability to change the parameter 1 and 2 of effect active, when an audio effect is active the rotation of the left Jog change the parameter 1 and right Jog change the parameter 2 (similar to Pioneer CDJs), when effect turn back off to the Jog function coming back to Pitch Bend / Scratch.
Old mapper action was "effect active ? param_multiply 300% & effect slider 1 : jog_wheel", if you don't like new 2 Jogs way to control effect you can past the old one in VDJ mapper page.
In the Hercules 4-Mx when an audio effect is active the rotation of the Jog change the parameter 1 and the Ctrl knob change the parameter 2 (similar to Pioneer CDJs), when effect turn back off to the Jog function coming back to Pitch Bend / Scratch and the Ctrl knob change the Filter.
To reset the filter push Shift.
In the Hercules Steel the effects parameter 1 and 2 can be changed with the two top left knobs, when the "Applt Ctrl. On" Led it's ON it indicate if knobs works for Deck A or B, in Select mode the two knobs it apply the filter of DecK A and B.
- Ability to scroll fast within the track with Jog, just press the |< or >| button and rotate the Jog.
- Pitch bend make short seek when track is in pause
- Ability to make "browsing" of the tracks with jogs, simply hold the "Cue Select" or "Up" or "Down" buttons on the deck and rotate the Jog. (No Hercules MK2). Note: that only works on one deck/jog at one time.
- Hold on the load button for more than half a second to unload the track from the deck.
- Fx and Loop leds blink when Fx or Loop are activated into Hercules MP3, MK2 and HDJC(MK1).
- Added blink on Play/Pause buttons when the song is paused (No Hercules Steel because it have the Stop led).
- Advance configuration of the 6 + 6 (shift mode) buttons in 4-Mx, RMX and Steel to use FX, Loop and 6 Hot Cues.
BUTTON1 -> loop_button
BUTTON2 -> effect active
BUTTON3 -> effect select +1
BUTTON4 -> loop_double
BUTTON5 -> loop
BUTTON6 -> loop_half
BUTTON7 -> holding ? delete_cue 1 : hot_cue 1
BUTTON8 -> holding ? delete_cue 2 : hot_cue 2
BUTTON9 -> holding ? delete_cue 3 : hot_cue 3
BUTTON10 -> holding ? delete_cue 4 : hot_cue 4
BUTTON11 -> holding ? delete_cue 5 : hot_cue 5
BUTTON12 -> holding ? delete_cue 6 : hot_cue 6
In the RMX the Source button is used like a shift, Hold on it for more than half a second to enable/disable Timecode_bypass.
- Advance configuration of the 3 + 3 (shift mode) buttons in DJ 4Set to use FX, Loop and 3 Hot Cues.
BUTTON4 -> holding ? delete_cue 1 : hot_cue 1
BUTTON5 -> holding ? delete_cue 2 : hot_cue 2
BUTTON6 -> holding ? delete_cue 3 : hot_cue 3
MODULATE- -> loop_half
MODULATE+ -> loop_double
- Advance configuration of the 4 + 4 (shift mode) buttons in MK4 and MP3 e2 to use FX, Loop and one sample.
BUTTON1 -> loop_half
BUTTON2 -> loop_double
BUTTON3 -> loop
BUTTON4 -> sampler play_stop
BUTTON5 -> effect select -1
BUTTON6 -> effect select +1
BUTTON7 -> effect active
BUTTON8 -> sampler rec
Note: Loop under 1/8 or bigger then 32 don't work with actions loop_half & double, if you don't want this limitation change "loop_half" to "loop_length 50%" and "loop_double" to "loop_length 200%".
To download latest Hercules driver go here -> http://ts.hercules.com/eng/index.php?pg=files_faq
v1.8
BUTTON5 -> loop
BUTTON3 -> loop
geposted Sat 18 Jun 11 @ 4:28 am
I NEED U MAPPER PACK
geposted Mon 03 Oct 11 @ 5:01 am
Sorry, mappers are only available to users who have purchased or upgraded to the full VirtualDJ Professional: http://www.virtualdj.com/buy/index.html
Your RMX DJ Console entitles you to a considerable discount off the cost of upgrading. Please click on the above purchase page to receive this.
geposted Mon 03 Oct 11 @ 5:22 am
Good work Cioce!.....
geposted Tue 04 Oct 11 @ 6:58 pm
