How do I burn a CD using Virtual DJ LE (mixtrack)
geposted Sat 02 Jul 11 @ 3:32 pm
You can't burn a CD directly from within VirtualDJ.
You will need to record your set using the record feature and then use 3rd party CD burning software on your computer to burn it to CD.
NOTE: Recording capabilities in VirtualDJ LE are limited. These only allow you to record to a single file. For more advanced recording capabilities including the ability to split the song into multiple tracks (Either automatically on crossfade or manually via the CUT button), you will need to upgrade to the full VirtualDJ Pro at a discount: https://virtualdj.com/buy/
geposted Mon 04 Jul 11 @ 8:08 am
on virtual dj 7 gives you the option to burn a CD or a file......On virtual dj 8 only gives you the option to create a file....how do you burn a CD on virtual dj 8
geposted Tue 16 Sep 14 @ 1:22 pm
You can't burn a CD directly from within V8.
geposted Tue 16 Sep 14 @ 6:06 pm
