Forum: VirtualDJ Skins
Topic: NS6 SKIN - Page: 3
great skin i need to have it in 1366x768 HD iis this possibble thanks Ing?¿¿?
muito show
thanks
kevinh54 wrote :
thanks
That is why we are. Greetings friend
SICK
xsushi4me wrote :
SICK
I'm back... AGAIN.....
Great Skin !!!! Just got the NS6 and it works well with Serato Itch but I was used to VDJ and wanted a new skin to match and this is perfect !!! great Job !!
The only comment is that the pitch slides are inverted , in other words , when making song faster , on the NS6 you slide down while on your skin it shows sliding up !!! Otherwise PEREFCT !!!!
Ok.. I fix this bug...
Muy bonita la piel, Ing pero la he probado con mi Numark Ns6 y me limita en algunas cosas.
1-. Los efectos funcionan ,pero no se me visualizan en la skin para poder elegir.
2-. La Sync del deck 1 se bloquea y no funca.
espero me puda ayudar con eso.
Felicidades buen trabajo.
Español
Bueno no he tenido mucho tiempo para hacer nuevas cosas y actualizar las ya existentes, pero estos dias me dare el tiempo necesario para hacerlo... Gracias por tus comentarios.
English
Good I have not had long time to do new things and to update the already existing ones, but these days me dare the time necessary to do it… Thanks for your commentaries.
Hello,
I started using this skin as soon as I got my NS6 and it's great.
However I have a problem with it: when I use the "FX SELECT A" or "FX SELECT B" on the NS6, and I am viewing the "MIXER" view (where you see the decks, and the "active" effect and effect "dropdown"), these two values do not change, even though the actual effect that is selected *IS* changed, and you can see that if you activate it, or if you switch to the "effects" screen.
Is there any way for the selected effect to be shown in the mixer screen as if you click on the "selected effect" box?
Thank you very much for an excellent skin !!
Kind regards,
Chris
I am going to review it… Any update was not published yet until the VDJ8 launching
Any idea when that is coming? (VDJ8 and/or new skin update :-) ) ?
I will be to the expectation of these 2 great news.
ola amigo puedes mandarme ese skin esta bakano
Hello,
is it possible to get that skin in 1280 x 800 for my MacBook?
Thank you in advance!
DJ-Evangel wrote :
Hello,
Sure.... I'm working in this resolution and more... In a few days I'll come back.
50%
