VDJ is great for live performances, but I need a tool for making perfect CD mixes, where you can go back and adjust something if you want, and stuff... You know what I'me talking about. Any suggestions?
geposted Fri 29 Aug 03 @ 8:11 pm
Try Mixmeister Pro it takes a while to get use to but is ace once you do.
Its a cut and paste mix program that will let you mix live.
geposted Sat 30 Aug 03 @ 12:42 am
I know about Mixmustard. Anything a little more flexibile out there???
geposted Sat 30 Aug 03 @ 8:36 am
Acid Pro
Soundforge
Cooledit
but mixmeister is the best. Ive used them all. Only this one gave me the flexibility to do everything I wanted
Soundforge
Cooledit
geposted Sat 30 Aug 03 @ 2:05 pm
It was most likely best to you becouse the other two arent even made for making mixes, they are for sound editing and Acit is for production :)
Ok, SF and CE are for mixing, but not this kind of mixing, they are for studio mixing
geposted Sat 30 Aug 03 @ 5:03 pm
what parameters are you wishing to go back and adjust?
Sound leveling or actually beat matching and stuff
geposted Sat 30 Aug 03 @ 7:03 pm
Both
geposted Sat 30 Aug 03 @ 10:24 pm
