hey i would like to be able to mapp my rmx so that i can add an echo (reverb) effect on the microphone. Can anyone help?
geposted Fri 15 Jul 11 @ 4:14 pm
You have to use a 4 deck skin and route the mic (or Aux) to one of the decks, probably use deck 4. Then you can apply any of your effects to that deck.
Not sure about the RMX, but this is how it is done on the NS7.
geposted Sat 16 Jul 11 @ 3:27 pm
thanks but that setup dnt work for the rmx
geposted Mon 18 Jul 11 @ 4:38 pm
The RMX is the limiting factor here.
To do what you want, you'll either have to buy an external FX box to feed your mic through before it plugs into the RMX, or plug your mic into your computer, not the RMX.
geposted Mon 18 Jul 11 @ 5:52 pm
