Hi all,
just wondering if anyone has tried using the mixtrack pro in a 4 deck way by mapping it themselves or some thing like that?
Regards Dj Klepht.
Regards Dj Klepht.
geposted Tue 26 Jul 11 @ 6:52 am
Map this script to a button you don't use on your Mixtrack,
device_side 'left' ? Deck 1 leftdeck ? deck 3 leftdeck & deck 3 select : deck 1 leftdeck & deck 1 select : deck 2 rightdeck ? deck 4 rightdeck & deck 4 select : deck 2 rightdeck & deck 2 select
Then use a four deck skin and you might have to go into the advanced sound config and route your decks out.
Let me know how it works out for ya.
Huey
Huey
geposted Tue 26 Jul 11 @ 10:16 am
Works perfect for controlling 4 decks man, really well actually. havnt tried routing though any suggestions for advanced config as i'm not that smart when it comes to it, could i use the output 1 and 2 on the back of the mixtrack pro for each channel?
Regards Dj Klepht
Regards Dj Klepht
geposted Tue 26 Jul 11 @ 9:18 pm
Hey, it works just perfect. but I've got one question, how to output the deck no onto a LED button (using a mix-track pro 3 wheel button) thanks :)
geposted Mon 01 May 17 @ 1:34 pm
ill dig out my mixtrack pro mapper, it has a 4 deck setup and loads of extra effects, samplers etc. even has a sampler record button for on the fly mashups and accapella recording
geposted Wed 03 May 17 @ 4:27 pm
