why when i set "deck 1 cross_assign RIGHT" on every rerun VDJ, it becomes to LEFT?
i just want it on right side please... don't want to do this every time!
geposted Sun 31 Jul 11 @ 8:17 am
just map it to oninit, then it will assign that way everytime you plug in your controller
you could also use..
crossfader_hamster
or
param_invert & crossfader
or if you want to swap between them, you could make a shift button
shift
toggle 'normalfader'
crossfader
var 'normalfader' 1 ? crossfader : param_invert & crossfader
that way if you hit the shift button you will be back in normal mode otherwise you will default as goofy fader
crossfader_hamster
or
shift
crossfader
geposted Sun 31 Jul 11 @ 8:37 am
here i can't see any oninit word in my mappers tab..! and i haven't controller yet
i made this button:
var 'cross' 1 ? deck 2 cross_assign left & deck 3 cross_assign right : deck 2 cross_assign right & deck 3 cross_assign left
on hit, deck 2 sets to left but after restart VDJ deck 2 is right!
i think this way can't make a default thing; i want ability to save cross sides on next update
i made this button:
geposted Sun 31 Jul 11 @ 9:39 am
all you should need to map for the crossfader is
var 'cross' 1 ? crossfader : param_invert & crossfader
or if you really want to keep that code you could just put it on your crossfader, that way whenever you move the crossfader you will be setting the cross assigns, but it is an incredibly long way of doing something short like swapping the way the crossfader moves, it will probably have a little lag when swapping between normal and hamster
crossfader & var 'cross' 1 ? deck 2 cross_assign left & deck 3 cross_assign right : deck 2 cross_assign right & deck 3 cross_assign left
ONINIT is hidden up the top of the mapper, in the key learn drop down box
geposted Sun 31 Jul 11 @ 9:59 am
if you dont use any controller, you may also add a line at the xml file of the skin you use as
<INIT action="........"/>
geposted Sun 31 Jul 11 @ 2:25 pm
thank you guys.. init code solved my problem
now i have another question:
is there an init code for sliders? for example:
<slider action="" init="param_equal 50%">
whitout any action, default parameter is zero percent
geposted Mon 01 Aug 11 @ 1:42 am
you can use anything with ONINIT... but you need to word it a little differently... e.g. "deck 1 eq_low 50% & deck 1 eq_mid 50% & deck 1 eq_high 50% etc..."
geposted Mon 01 Aug 11 @ 3:55 am
i knew it
but, apparently there's no way to init [e.g. 50%] a slider without any action
anyway, thanks a lot
geposted Mon 01 Aug 11 @ 5:04 pm
not sure I follow you... you can set any parameter to any value, but yes it does need to be attached to something, you couldn't set nothing at a percentage, but you could set for example the volume at 100% or vinyl_mode 1 (on)
geposted Mon 01 Aug 11 @ 6:55 pm
