Is there a way I can "bleep" out curse words from songs. Do they have an effects download for that?
geposted Mon 08 Aug 11 @ 10:09 am
get loop roll from the plugin section and map a key or a button to
deck default effect "looproll" active while_pressed & deck default effect "looproll" slider 2 70% while_pressed & deck default effect "looproll" slider 3 0% while_pressed
it will play a 1 beat loop from the buffer in reverse, there is way more fun to be had with this effect as well, I highly recommend it.
geposted Mon 08 Aug 11 @ 10:16 am
maybe you can map a key to the "dump" function...
basically "dump" reverses your music while keeping you on beat...here is the definition from the
VDJpedia:
dump : reverse the playback direction while dump is active, then when deactivated, start again forward from where the song should have been if it had been playing forward during the dump.
VDJpedia:
geposted Wed 10 Aug 11 @ 9:05 pm
Use effect "forward_reverse" as it does pretty much the same thing. When you hold down the button it will play the bad word in reverse but the song keeps going forward.
Keith
Keith
geposted Thu 11 Aug 11 @ 4:17 pm
