Forum: Old versions
Topic: Skips While changing EQ's
When i am adjusting the eq's on the track i'm cueing it makes the music skip and go out of sync, so if i do a small adjustment while actually mixing the beats go out of sync.
i'm sure this has been reported before but not yet fixed :S
geposted Mon 01 Sep 03 @ 12:19 am
hi DJ
This problem has been there from the start of VDJ... it still happens to me quite often.
The only way around it I have found is to use keyboard shortcuts and 'nudge' the frequency crossfader the required direction..
It only seems to happen when using say the mouse to action the frequency crossfade whilst using keyboard to crossfade the tracks simultaniously.??
I use an external mixer alot of the time so it doesnt cause a problem then. but on the smaller gigs, i have to remember to use the nudge rather than the actual frequency crossfader..
It may be worth you trying the above to see if it resolves the issue, at least then it will hopefully help the team detect the cause easier..
Regards
stu
Hi, Stu ;)
Tried using keyboard shortcuts and its still the same for me!
