Hi,
Is it possible to add to the browser a specific song, specifying its full path, e.g.
ADD "path_to_my_song".
If not is there any workaround?
Thanks
Tuvia
Thanks
Tuvia
geposted Thu 18 Aug 11 @ 10:20 am
If you need to change the path of a file then you can do it using the "Move" command, right cliick on the file, then go to "File Operations" and choose "Move To" a window will open and navigate to the folder you need and click OK, and your done....Now if you need the file path, then you will have to go into file Info to get it...
Good Luck,
Joey...
Good Luck,
Joey...
geposted Thu 18 Aug 11 @ 1:41 pm
Do you mean a new column in the browser with {FilePath + FileName} ? Why ?
geposted Fri 19 Aug 11 @ 1:48 pm
