WHY IS MY CPU USAGE ALWAYS FULL AND IT TAKES SOO LONG FOR MY TRACKS TO LOAD, THIS IS ONLY HAPPENING SINCE I UPDATED MY VDJ TO 7 AND I SHUT DOWN THE INTERNET SWITH OFF ANTI VIRUS, FIREWALL ALL OTHER PROGRAMS ETC.... STILL TOOO SLOW????
geposted Mon 12 Sep 11 @ 7:04 am
Have you brought up your task manager to see what's eating up your CPU? The CPU meter on VDJ skins is the overall CPU usage of your system, not the CPU usage of the VDJ process only!
geposted Mon 12 Sep 11 @ 7:43 am
Have you resized or maximised the VirtualDJ skin?
This can commonly cause high CPU usage depending on your computer's graphics card's capabilities.
Ideally, you should use the skin at its native size or a custom skin that matches your screen's resolution: https://virtualdj.com/addons/skins.html
Please see https://virtualdj.com/wiki/Common%20PC%20Performance%20Issues.html
geposted Mon 12 Sep 11 @ 12:41 pm
How much Ram you have? ? and what kind processor are you using?¿
geposted Mon 12 Sep 11 @ 5:23 pm
^ + 1
geposted Mon 19 Sep 11 @ 11:53 pm
my cpu usage is full on virtual dj and im using a amd dual core processor 1.0 ghz
geposted Sat 02 Nov 13 @ 11:15 am
Please see our FAQ pages:
https://virtualdj.com/wiki/Performance%20Issues.html
geposted Sat 02 Nov 13 @ 3:31 pm
Ok I am getting the same issues and have removed or shut down any processes that are not critical. Also serves noting I am on a i7 1.6 ghz with 8 gb of ram 512 dedicated video card with 3 gb total video card ram running on windows 8.1. I am getting the CPU usage peeking into the red and a stutter of music plus a massive drop in speed on the wave forms for each deck. Seems to be no reasoning as one minute it works perfect than it spikes nearly crashing than comes back for a few minutes. I am also using iremote on an iPad 2 and the denon 6000. Any thoughts of what else to look into?
geposted Thu 19 Dec 13 @ 12:13 am
open vdj and set it running and minimise then open task manager and watch what happens.
geposted Thu 19 Dec 13 @ 4:50 am
Please check the link above to ensure that your computer is optimised for DJ performance: https://virtualdj.com/wiki/Performance%20Issues.html
In particular, make sure that you have not resized or maximised the VirtualDJ skin (User interface.) This can cause performance issues on some computers depending on your computer's graphics card's capabilities. This is due to the fact that it must scale the skin to the new size in real time.
If it's OK one minute and then bad the next, then this could be an overheating issue (Your computer's CPU is slowing down automatically to prevent overheating.) Make sure that all vents of your computer are not blocked or clogged up with dust and make sure that the cooling fans are still operational.
geposted Thu 19 Dec 13 @ 5:43 am
