Please make the recording feature of VDJ have a recording level meter with a gain level adjustment knob.
Do it soon, please.
Thanks
Do it soon, please.
Thanks
geposted Tue 13 Sep 11 @ 1:16 am
+1 It would be nice to know how far I can push the volume without waiting till the end result. Not sure about the need to do it soon though..
I looked into the Skin and VDJ script commands to see if there was a command for it, or if recording could be routed to a deck (as dumb as it sounds) like a Mic or Line in can. No luck for a quick fix there.
geposted Tue 13 Sep 11 @ 8:13 am
+1 and it can't get here soon enough. Luckily my Audio 8 has a meter on it so I can get by with out on the skin. It is a much needed addition though.....
Huey
Huey
geposted Tue 13 Sep 11 @ 8:59 am
Plus 3, I only have issues when recording to mp3 at a high quality. Wav format I have had better luck but the meter would be beneficial
geposted Sat 12 Nov 11 @ 3:59 pm
do a test run 1st before you do a 80 min mix
geposted Sun 27 Nov 11 @ 1:24 am
