Forum: Old versions
Topic: using Airplay with Virtualdj
Is there a way to use Airplay with this program?
I have a new receiver and I can play my Itunes tunes on the home stereo system, but don't know how to make virtualdj do it.
Thanks
DJ CAMPERS
geposted Tue 20 Sep 11 @ 11:11 pm
I myself am trying to do the same thing instead of buying a mac mini which would give me audio from one section of my audio section, I thought of the airplayplayer but i want something that will update with apple to make sure my purchase isnt in limbo. If you find a solution please post it and I will do the same, thank you and your welcome in advance.
Airfoil works very good !
Thanks !
Airfoil 4.8.3 trial (luckily I didn't pay for it yet) doesn't work with Virtualdj 8.
And I do have recent stuff like late 2013 RMBP, Time Capsule,...
Anyone else? Says something about "process 15XXX not found"
I am able to use airplay.... Are you trying to stream audio or video?
streaming... maybe I should reboot the whole system to make sure that's not the problem. I'll do that tomorrow. Logging out now. :)
