Hi guys. If you have massive hard drives obviously having all your video's as VOBs would be ideal, however due to the vast amount of tracks us digital DJ's are expected to have these days it's not really viable. So was wondering what video format compression you use?
I have a problem with certain mpegs. they play ok in WMP but wont play in VDJ???
It just says Error when I try to play .mpg (MPEG4) files in Virtual DJ. They play in windows fine. I had to install a codec on win XP to get them to work, but the codec I have won't install under win 7 (it's one of those you have to right click on then go to "install" in WinXP, but win 7 doesn't have that option?
Im going to re-encode the ones that don't work so wondered is .MP4 the best compression method to use and what software do you use to convert the video's ?
Thanks.
Thanks.
geposted Sat 24 Sep 11 @ 9:34 am
http://www.divx.com/
try it, I love it. very mature application, encodes to .divx format which is .avi (just change the ext)
I've used divx for years and for many different reasons. great quality videos at a smaller file size.
I'm in the planning stages of converting all my vob files to avi also.
I hope to have a better ability to adjust audio quality in some of these files once finished.
I also use the divx codec to record video sets with VDJ. http://www.facebook.com/video/video.php?v=2378237981769
Plus divx plays nicely on most all devices.
If you find something cool, please share with us.
Good luck,
T
Good luck,
T
geposted Mon 26 Sep 11 @ 12:24 pm
You can try ddvideo video to mp4 gain.It works great for me.support mp4 video gain,mp3gain.also keep the original video size by OriginalSize with high quality and very easy to use.
It supports many mp4 player:like iPod,iPhone.PSP.PS3,XBOX,Zune,Archos etc .
visit http://daydayvideo.com/video-to-mp4gain.htm to learn more information
geposted Mon 03 Oct 11 @ 4:07 am
hi guys the problem i have when i try to rip from dvd is that only if i rip the format as a vob does the lip sink stay, if i try to go to mp4 then its very hit and miss
johnny
johnny
geposted Tue 18 Oct 11 @ 9:06 pm
And where i can find analog for mac os?
geposted Wed 19 Oct 11 @ 12:36 pm
I use MPEG Streamclip: video converter for Mac & Windows ( http://www.squared5.com/m ) to convert my vob files into MP4 (h264).
For me mp4 workes as best.
geposted Thu 20 Oct 11 @ 7:01 am
I use different files.
MKV
VOB
FLV
M2V
AVI
Mpeg sometimes works, sometimes don't (just like te story above) in the begining they have worked, but now on error
it's possible that i don't have the right codec.
so i try to convert them to Dvix on the link above)
MKV
VOB
FLV
M2V
AVI
geposted Wed 26 Oct 11 @ 1:27 pm
I use Videotoolz as my record pool and everything (videos) I download is in MP4 format...and they all seem to load pretty fast and work well.
geposted Fri 28 Oct 11 @ 11:36 am
I've been converting Promo Only vids to MP4 with Leawo dvd to mp4 converter. It works fast and gets great results to boot. I tried Handbrake before but that took way too long to convert. Shoot me a message if you wanna know more.
geposted Fri 18 Nov 11 @ 9:19 pm
MP4 (h.264) ..the standard scalable 2012 for videomix
geposted Sat 07 Jan 12 @ 7:29 pm
what is the best video format for videomix in mac??
i have a macbook pro 13 i5 with intel hd 3000.
mp4 //h264 and 1280x720??? maybe???
geposted Tue 19 Mar 13 @ 7:30 am
I wish to start virtual dj video mixing. Pls what is the best video format to use?
geposted Mon 19 Aug 13 @ 8:28 am
mp4
geposted Mon 19 Aug 13 @ 5:12 pm
How about using DAT file?
All I have is DAT files. The problem is, the music quality will drop very low when VOCAL effect is selected. It use to eliminate the voice.
Anybody can help?
Thank you.
Anybody can help?
Thank you.
geposted Thu 03 Oct 13 @ 7:42 am
