Forum: Old versions
Topic: Virtual DJ New Star 6 Not Work !
Hello,
I downloaded Virtual DJ New Star 6, and when I turn it on it says to me "the internal database is corrupted".
Then it changes my screen's resolution and I entered the program and run me an error message if a file is missing.
When I had Windows XP software worked fine for me.
I currently have Windows 7 proffesional 64BIT and the software does not work.
What to do?
geposted Thu 06 Oct 11 @ 8:08 am
You have downloaded an illegal cracked version of Virtual DJ. You can feel free to download the free home trial edition here:
http://www.virtualdj.com/download/free.html
The free version is for private home use only. For full functionality, you will need to purchase the Full Pro Version.
You are using an old illegal pirate version of the software.
If you like VirtualDJ, please support the software and its future development by purchasing it: http://www.virtualdj.com/buy/index.html
VirtualDJ v6 is an old and out of date version of the software. There have been many changes and improvements to the software since then (See http://www.virtualdj.com/wiki/VirtualDJ_History.html ) - We are now on v7.0.5
If you are using VirtualDJ for home use only without MIDI controllers/timecode/video, then you can download and use VirtualDJ v7 Home FREE from http://www.virtualdj.com/download/free.html - This version can be used completely free of charge for non-commercial use (It may not be used a DJ gigs where you are being paid.)
NOTE: Illegal versions usually do not work correctly and may contain bugs due to illegal modifications made to the software by the hackers who created the cracked version. They are also usually out-of-date versions of the software and may also contain viruses, spyware and other malicious software.
But the Virtual DJ software New Star 6th easier for me to do things and I can do even more beautiful remixes.
What i can to do ?
Perhaps there is a bit of a language barrier. The software you are using IS Virtual DJ. It's an old, pirate copy. That means it's STOLEN. STOP USING IT and upgrade to the latest version.
Please support the software and its future development by purchasing it: http://www.virtualdj.com/buy/index.html
If you are using VirtualDJ for home use only without MIDI controllers/timecode/video, then you can download and use VirtualDJ v7 Home FREE from http://www.virtualdj.com/download/free.html - This version can be used completely free of charge for non-commercial use.
Perhaps he will find this clearer:
אתה משתמש בתוכנה גנובה
I want to record in Virtual DJ you brought me that I write
** Record Error **
Cant open MP3 Encoder.
What to do??
how can i buy a full virtual dj software dat can work wth my pioneer xdj r1
