Hi there,
For some reason Virtual DJ has stopped loading and music from itunes that I add. I can access everything up that I already had in my library, but I can't access anything that I have added in the last couple weeks. Any ideas?
I have Mac OSX Lion, itunes 10.5, and Virtual DJ Pro 7.0.5
Thanks!
Thanks!
geposted Thu 20 Oct 11 @ 6:40 pm
This might help:
Go to settings, browser tab, and have virtual dj fix & check the directory where your files are stored.
geposted Fri 21 Oct 11 @ 11:17 am
Tried it, didn't do anything :(
geposted Fri 21 Oct 11 @ 11:22 am
I have a feeling that it may have something to do with the new file structure of itunes 10.5
geposted Fri 21 Oct 11 @ 11:34 am
May this will help ;-)
https://virtualdj.com/wiki/Playlist%20Itunes%20not%20showed.html
geposted Sat 22 Oct 11 @ 4:29 am
I had the same problem, also for about a week now. The link in the previous post did indeed solve my problem. Some update must have caused the library to rename itself I guess.
geposted Fri 28 Oct 11 @ 1:40 pm
That seems to have been the problem. Thanks guys!
geposted Sat 29 Oct 11 @ 12:30 pm
VDJ isn't recognizing when new tracks are added in iTunes and need to be scanned.
I have to use a playlist in iTunes to manually add the new tracks to the search DB so that the filter for whether they've been scanned will work correctly.
A very minor issue but VDJ isn't as tight with iTunes as Serato Scratch Live is.
geposted Sat 21 Jan 12 @ 11:33 am
Fix this problem now! This is unacceptable for software that costs hundreds of dollars. This is a joke!!!!! Very disappointed!
geposted Tue 14 Jan 14 @ 10:11 pm
VDJ and iTunes do not use the same database!
You need to add new music (folders or files) to VDJ serachdb and then do the BPM scan.
After that you will find the files also inside VDJ!
If you try to use iTunes playlists with VDJ you have to tell VDJ where to find!
This is what the link from above explain!
geposted Wed 15 Jan 14 @ 3:58 am
To add new music to VirtualDJ's database (So it's found when searching), please see:
https://virtualdj.com/wiki/Add%20to%20search%20DB.html
To analyse newly added music for BPM, etc., please see:
https://virtualdj.com/wiki/Pre-Analysing%20Your%20Music%20Collection.html
geposted Wed 15 Jan 14 @ 7:31 am
perfect :-)
geposted Wed 15 Jan 14 @ 9:38 am
