Hallo DJs
Heut bin ich mal wieder auf Eure Hilfe angewiesen.
Meine 1. Frage welcher von den beiden Playern ist besser?
2. Frage gibt es erfahrungen mit beiden Playern bei VDJ wenn ja welche?
3. Frage gibt es Mappings für die Player.
Ich sag schon mal Danke im Voraus...
geposted Fri 21 Oct 11 @ 6:05 am
Quote :
Does my controller have native support ...
... in VirtualDJ PRO FULL ???
This question is being asked more and more these days. And specially when it should not be. So how do you know ???
Clue #1 - Your product came with the VirtualDJ LE software. If it ships with VirtualDJ LE in the box, then it is supported in the PRO FULL version.
Clue #2 - If you haven't bought the controller yet, does the 'controller' show on our hardware page? http://www.virtualdj.com/products/hardware.html If controller is listed on that page we provide native support for it.
Clue #3 - Download and install the VirtualDJ Home FREE version - http://www.virtualdj.com/download/free.html After installation, run VirtualDJ Home FREE and go to the Config -> Mappers tab. From the button to the right of the drop-down list (top-left), click on it and deselect the option for 'Show only connected devices'. Now the drop-down list is populated with the entire collection of 'natively' supported controllers.
And if by chance you find that we do not provide native support, you can then look here to see if there is Community provided support for your device.
http://www.virtualdj.com/addons/controllers.html?category=all&order=default&search=
By the way - as of this post - VirtualDJ provides native support for over 120 items and there are 9 pages of 20 items to a page (180 downloads) in the Community provided downloads.
So Clue # 4 would be - if your controller has been on the market for over a year and is a very popular item - there is a 99% chance it is supported by VirtualDJ PRO Full.
geposted Fri 21 Oct 11 @ 6:07 am
Did wird ja immer schöner hier....1. Hab ich ne Voll-Version VirtualDJ Pro und 2. darf ich ja wohl auch sone Frage hier stellen wie jeder andere auch!!!!!!!
Danke
Danke
geposted Fri 21 Oct 11 @ 6:27 am
aloá,
die frage der mappings kannst du dir ja selber beantworten, wenn du mal in deine geräteliste schaust.
einfach den haken bei "zeige nur angeschlossene geräte" wegnehmen... violá... da siehst du das :)
der WiKI bereich hier hält auch einiges an antworten bereit :)
was erfahrung betrifft,
schonmal mit tabletop CD playern gearbeitet ?
Wenn ja, dann hast du mit pioneer meiner meinung nach das beste was geht.
was nun den rest betrifft... der cdj1000 MKII ist nicht unbedingt ein gängiges gerät ^^
mit dem 900er macht man nix falsch...
ob nun 850er, 900er oder auch 2000er... ich mag sie alle.. sogar den 3560er, obwohl mir der 400er besser gefiel :)
besser oder schlechter ist immer so eine sache... es geht eher darum, was man erwartet bzw was man den braucht.
und im normalfall, kann man sich die meissten fragen selber beantworten, wenn man denn mal ein kleines bisschen sucht...
einfach mal "cdj 900 + virtual dj" in die google suchmaske eingeben.... bekommst du endlose treffer..
gruss, der Kernspalt.
geposted Fri 21 Oct 11 @ 8:28 am
Den kannte ich ja noch gar nicht. Muss ich gleich mal googeln :p
geposted Fri 21 Oct 11 @ 9:25 am
Da isser....ob VDJ den Mappen kann *fg
geposted Fri 21 Oct 11 @ 1:57 pm
rofl....
ihr wisst schon was ich meine.,... aber gut ist der trotzdem..
bei richtigem mapping kommt da auf jeden fall ne FETTE line raus ^^
geposted Fri 21 Oct 11 @ 2:32 pm
Hallo,
Und danke für die Ausführungen...
Ja das mit dem Mapping hätte ich mir spaaren können, Ich wollte nur wissen ob es Probleme damit gibt.
Also der Zeit benutze ich die 800 MK II über Time-Cods.....!Ich hatte mir schon mal die 850er bestellt hab die aber wieder zurück gegeben..da es Fette Probleme mit VDJ gab...beim umschalten auf CD is der Player und VDJ abgestrürtst.
Deswegen die Fragen hier.
geposted Mon 24 Oct 11 @ 4:15 am
das mit den Abstürzen beim Umschalten auf CD dürfte sich mittlerweile aber erledigt haben. Seit dem lezten VDJ update gibt´s keine Probleme mehr beim hin und her schalten. Hatte das gleiche Problem mit meinen CDJ 350ern - jetzt klappt´s aber
geposted Mon 24 Oct 11 @ 4:43 am
das update kam aber net von vdj sondern es gab ne neue firmware seitens pioneer :)
geposted Tue 25 Oct 11 @ 9:56 pm
hi kennt sich jemand mit mischpult Pioneer cdj 700k 4 kanäle aus,
möchte mit vdj pro anschliessen(MIDI)
welche soundkarte brauche ich und wie schliesse ich das an?
Dankee.....
Dankee.....
geposted Thu 27 Oct 11 @ 4:51 am
