Is there a reason nobody has created a Numark V7 skin for Virtual DJ?
geposted Sun 13 Nov 11 @ 3:53 am
Maybe I do it, for version 8….
If nobody but does.
So… patience friends.
If nobody but does.
geposted Mon 21 Nov 11 @ 7:29 pm
Skins are made by users. That means that a user needs to build a skin that looks like V7 too.
Its not easy to make a skin, however if you re good enough with graphics you can try the Skin Creator Tool. https://virtualdj.com/addons/5990/Skin_Creator_Tool_-_Windows.html
There must be over 200 controllers out there, so its quite normal that not all controllers having a custom skin.
Bottom line, all you need to do is ask that and wait for a skinner to make such a skin if you re lucky (or Dj Ro makes one), or try yourself using the Tool above.
PS. I moderated all unnecessary posts. There is no need to argue for a skin. Peace :)
geposted Mon 21 Nov 11 @ 9:48 pm
Right on :)
geposted Mon 21 Nov 11 @ 11:07 pm
