Forum: VirtualDJ Plugins
Topic: Auto play at specific time
I was just wondering if anyone could help me...i am looking for plugin that will let set a point in a song playing on deck one. Once vdj hits this point I want it to start playing deck 2. That is it and that is all…seems like a fairly simple thing but I just can’t find a way to do it other than by hand
geposted Wed 16 Nov 11 @ 10:35 pm
Look in your user manual under AutoMix section, Mix Cut "Exit Point", you could do this in the auto playlist, but only one deck mix not two, you can always do this cue point manually..
Good Luck,
Joey...
thanks i'll try that but i would realy like it to be on both decks
Then use the following command: automix_dualdeck
