I received a Nexus 7 tablet for Christmas. It is very neat. My first tablet. I bought several DJ apps the other night. Some of them resembled VDJ a bit as the wave form at the top was pretty close. I think the name of it was adj pro or something like that.
geposted Tue 08 Jan 13 @ 11:08 pm
Yeah I've got ADJ Pro on my S2, it seems to be the best of the bunch out there at the moment. Looks like Android still has a long way to go before it catches up with iOS based DJ apps though - apparently its a limitation to do with audio latency and the Android OS itself, until that gets sorted, any DJ app on Android is always going to be a bit, um, "meh".
geposted Wed 09 Jan 13 @ 4:31 am
Check out PdaNet+ w/FoxFi on the Play Store. Turns ur cell into a hotspot. The free version times out in about 10 mins. I paid the $8 for pro license. It works famously and obviously uses your data plan. If your grandmothered unlimited it's great because the $20/mo hotspot from VZW only allows a few gb. It stayed connected to my laptop for my whole gig to run Firetext and if you need to search a requested song, you've got the www.
geposted Tue 07 May 13 @ 1:28 pm
Or on the S2, go to "settings", and select "tethering and portable hotspot"... ;)
geposted Thu 09 May 13 @ 10:14 am
Does anyone have or know of a android remote app for virtual DJ 7.4 pro?
geposted Mon 17 Mar 14 @ 6:55 am
I all so have a vonino tablet and would like to down load virtual DJ 8 to it can you help me because right know its not working thanks.
geposted Mon 18 Aug 14 @ 11:37 am
You can't run Windows or Mac software on a tablet with an Android operating system.
geposted Sat 08 Nov 14 @ 5:34 am
I have the normal virtual dj.am a up and coming dj what shall I upgrade too and needs to have special affects apart from that boring siren
geposted Fri 13 Mar 15 @ 10:03 am
hi guys i have a tab3 7.0 tm-210 im trying to connect with vdj but its not connecting please help me
geposted Mon 29 Jun 15 @ 4:02 am
Have you installed bonjour on your PC?
geposted Mon 29 Jun 15 @ 9:35 am
