Well i tried to configure but it doesnt work.
Need to know the value of loop in and loop out
I need some help.
thanks.
I need some help.
thanks.
geposted Wed 03 Sep 03 @ 1:09 pm
Exemple:
sc key="num-" action="loop_in" /
sc key="num+" action="loop_out" /
Why don't you use VDJ to create your shortcuts??!!!
geposted Wed 03 Sep 03 @ 1:17 pm
I used Vdj to create the shortcuts.
But it didnt work.
Wich value do i use???.
Thanks.
But it didnt work.
Thanks.
geposted Wed 03 Sep 03 @ 1:30 pm
You don't have to use value.
VDJ use the position of the song when you strike your shortcut.
geposted Wed 03 Sep 03 @ 1:39 pm
It works !!
Thanks again
Thanks again
geposted Wed 03 Sep 03 @ 1:59 pm
You're welcome.
geposted Wed 03 Sep 03 @ 3:15 pm
I found it necessary to have 3 shortcuts to have loop in/loop out work properly. I set up all three with VDJ.
1. Set one shortcut for loop in
2. Set another for loop out
3. Set a third for loop and reset the loop with that shortcut
geposted Thu 04 Sep 03 @ 11:01 pm
