Hey Guys,
I'm using Mixed in Keys for harmonic Mixing and the program can already connect to iTunes and traktor. Would be nice if it could also connect to vdj ;)
best regards
Quaii
best regards
Quaii
geposted Mon 09 Jan 12 @ 12:26 pm
Sadly, no software will do this!
- Traktor won't do it
- Serato Scratch/Itch won't do it
- Torq won't do it
- Ableton won't do it
- VDJ won't do it
- CDJs/RekordBox won't do it
Personally, I think the best way to use Mixed In Key effectively is to set it to write the KEY value in the KEY field *and* the comment tags.
This way, you can make SmartPlaylists in iTunes and have playlists for each KEY.
In fact, I have playlists for "3B Possibilities" which include tracks that are 3B, 4B, 2B, and 3A.
This way, you can have full control of your harmonic mixing from within VirtualDJ!
- Torq won't do it
- VDJ won't do it
geposted Tue 10 Jan 12 @ 8:11 pm
software can find the key for you, but i think it's more practical to use Comment tag + iTunes library + SmartPlaylists
no software can do a mass-analysis of your entire library, scanning Key along the way.
Traktor does a good job of analyzing the waveform ONCE so that it instantly loads the next time you play.
however, no software will put the Key in for all your music ~ (except mixed in key, lol)
geposted Tue 10 Jan 12 @ 8:12 pm
geposted Wed 11 Jan 12 @ 5:31 am
What about the compartible songs Filter-Folder....
Is does the same and gives you perfekt matching songs.
I got this one:
I got this one:
bpmdiff<=4 and keydiff=0
geposted Wed 11 Jan 12 @ 6:55 am
The problem with VDJ is that Atomix seem to think every song in the world is in a minor key.
This clearly isn't the case.
Songs often also change key, which the latest MIK handles - but only when you load the song into the MIK player.
geposted Fri 13 Jan 12 @ 12:58 pm
