Can you give me the version number please as reported in the plugin information window in the VDJ browser?
Can you also please tell me what version of VDJ you are using exactly - from your account it looks like v7.0.5 but please confirm.
Then I need you to give me a step by step guide to replicate your issue. I tested ShowLogo before posting earlier and all transitions were working fine for me - so I will need *detailed* information to replicate the problem.
geposted Sat 28 Apr 12 @ 12:03 pm
hello friend. version of the plugins is Last update: Tue 3 April 12 @ 11:21 a.m.
is VirtualDJ version 7.0.5 for Mac and my system is "osx 10.7.3 lion"
macbook pro.
greetings.
macbook pro.
greetings.
geposted Sat 28 Apr 12 @ 2:09 pm
geposted Sat 28 Apr 12 @ 4:10 pm
http://www.virtualdj.com/addons/14254/ShowLogo_(Mac).html
ver. 3.11 ?
ver. 3.11 ?
geposted Sat 28 Apr 12 @ 4:24 pm
OMG! So excited about the Cam effect for Mac. I love it.. I just have one issue with it. Its using ALLOT of cpu and actually crashed my computer about 10 different times. The last one was durring my set last night at the night club. Is there a way aroumd the crashes or something I can do? I'm running it threw photobooth as means to set my external cam as the default as apposed to the iSight cam. Virtual DJ 7, vestax VCI-400, Macbook Pro 15, 2G memory, core 2 duo 2.67 (I believe) .Thanks y'all :-) ♪♪
geposted Sat 28 Apr 12 @ 6:57 pm
andresdj_mix_ wrote :
ver. 3.11 ?.....
Is that exactly what it says in your plugin information window in the VDJ browser when you are running Virtual DJ - I'm trying to rule out an installation issue for example.
I'm still waiting for exact step by step instructions to replicate your problem. Help me to help you, if you can't provide me information then I can't do anything.
geposted Sat 28 Apr 12 @ 8:31 pm
Yup, quite possible. I can't do anything about that. I'm unsure why you're doing it as you are - you can select which camera to use from within the plugin?
Without a crash report I have no way of knowing what happened to cause your crash I'm afraid. I've been unable to crash the plugin myself so that report is critical.
geposted Sat 28 Apr 12 @ 8:33 pm
Dear sorry you can not explain it because I do not speak English, I download the latest version of the plugin showlogo mac, but when you install this plugin and open vdj I have no problems, it is only when I run the plugin showlogo automatically stops the mix vdj videos, pictures can not melt, ie all the effects that have images fade the crossfader is acting as a simple cut, and to merge virtual dj video again I have to close it and open it again without activating showlogo.
I hope that I can understand the opposite case of recording a video.
Greetings and thanks for responding.
geposted Sun 29 Apr 12 @ 9:37 pm
No theres no way to select what cam to use with the plugin.. The plugin for PC you can but the one for Mac you cannot. You can only change size etc. On Mac I have to go to Photobooth and make the systems default cam being the webcam as apposed to the isight built in cam that faces me. Ill post the crash report right now.
geposted Mon 30 Apr 12 @ 2:18 am
Process: VDCAssistant [1380]
Path: /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/Resources/VDC.plugin/Contents/Resources/VDCAssistant
Identifier: VDCAssistant
Version: ??? (???)
Code Type: X86-64 (Native)
Parent Process: launchd [88]
Date/Time: 2012-04-27 01:33:17.559 -0700
OS Version: Mac OS X 10.6.8 (10K549)
Report Version: 6
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x000000000000000d
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Thread 0 Crashed: Dispatch queue: com.apple.main-thread
0 VDCAssistant 0x0000000100031138 0x100000000 + 201016
1 VDCAssistant 0x0000000100033ef9 0x100000000 + 212729
2 VDCAssistant 0x0000000100033f76 0x100000000 + 212854
3 libSystem.B.dylib 0x00007fff801ed9a8 mach_msg_server + 357
4 VDCAssistant 0x0000000100033cdf 0x100000000 + 212191
5 VDCAssistant 0x0000000100001f5c 0x100000000 + 8028
Thread 1:
0 libSystem.B.dylib 0x00007fff80170d7a mach_msg_trap + 10
1 libSystem.B.dylib 0x00007fff801713ed mach_msg + 59
2 com.apple.CoreFoundation 0x00007fff80d8a932 __CFRunLoopRun + 1698
3 com.apple.CoreFoundation 0x00007fff80d89dbf CFRunLoopRunSpecific + 575
4 com.apple.CoreFoundation 0x00007fff80d89b46 CFRunLoopRun + 70
5 VDCAssistant 0x0000000100004a76 0x100000000 + 19062
6 libSystem.B.dylib 0x00007fff801a9fd6 _pthread_start + 331
7 libSystem.B.dylib 0x00007fff801a9e89 thread_start + 13
Thread 2: Dispatch queue: com.apple.libdispatch-manager
0 libSystem.B.dylib 0x00007fff80189c0a kevent + 10
1 libSystem.B.dylib 0x00007fff8018badd _dispatch_mgr_invoke + 154
2 libSystem.B.dylib 0x00007fff8018b7b4 _dispatch_queue_invoke + 185
3 libSystem.B.dylib 0x00007fff8018b2de _dispatch_worker_thread2 + 252
4 libSystem.B.dylib 0x00007fff8018ac08 _pthread_wqthread + 353
5 libSystem.B.dylib 0x00007fff8018aaa5 start_wqthread + 13
Thread 3:
0 libSystem.B.dylib 0x00007fff8018aa2a __workq_kernreturn + 10
1 libSystem.B.dylib 0x00007fff8018ae3c _pthread_wqthread + 917
2 libSystem.B.dylib 0x00007fff8018aaa5 start_wqthread + 13
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000005 rbx: 0x00000001004046f0 rcx: 0x0000000000014800 rdx: 0x0000000100111ef0
rdi: 0x0000000101011200 rsi: 0x00007fff7001f650 rbp: 0x00007fff5fbff8d0 rsp: 0x00007fff5fbff8b0
r8: 0x000000000000000f r9: 0x0000000101011200 r10: 0x0000000000002000 r11: 0x0000000000000000
r12: 0x0000000100111f20 r13: 0x0000000100111d50 r14: 0x0000000100111d50 r15: 0x00007fff5fbff8ec
rip: 0x0000000100031138 rfl: 0x0000000000010206 cr2: 0x000000000000000d
Binary Images:
0x100000000 - 0x100074ff7 VDCAssistant ??? (???) <6D17B21C-C695-9D5E-614F-BE270A169A8B> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Resources/VDC.plugin/Contents/Resources/VDCAssistant
0x10039a000 - 0x1003a4ff7 com.apple.iokit.IOUSBLib 4.1.5 (4.1.5) <AF6E3936-8B3B-F112-C821-417456BC812F> /System/Library/Extensions/IOUSBFamily.kext/Contents/PlugIns/IOUSBLib.bundle/Contents/MacOS/IOUSBLib
0x1127e1000 - 0x112807fff GLRendererFloat ??? (???) <490221DD-53D9-178E-3F31-3A4974D34DCD> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFloat
0x1129e0000 - 0x112b73fe7 GLEngine ??? (???) <53A8A7E8-4846-D236-F3D9-DA3F2AF686D8> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
0x112ba4000 - 0x112fc7fef libclh.dylib 3.1.1 C (3.1.1) <432F5475-F934-92A0-FB49-78F03DA82176> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib
0x200000000 - 0x200787fe7 com.apple.GeForceGLDriver 1.6.36 (6.3.6) <4F23289A-D45A-0630-8D7F-4C35A4D2AA00> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver
0x7fff5fc00000 - 0x7fff5fc3be0f dyld 132.1 (???) <29DECB19-0193-2575-D838-CF743F0400B2> /usr/lib/dyld
0x7fff80003000 - 0x7fff80003ff7 com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <4CCE5D69-F1B3-8FD3-1483-E0271DB2CCF3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff80004000 - 0x7fff80064fe7 com.apple.framework.IOKit 2.0 (???) <4F071EF0-8260-01E9-C641-830E582FA416> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff80170000 - 0x7fff80331fef libSystem.B.dylib 125.2.11 (compatibility 1.0.0) <9AB4F1D1-89DC-0E8A-DC8E-A4FE4D69DB69> /usr/lib/libSystem.B.dylib
0x7fff804bc000 - 0x7fff804bfff7 libCoreVMClient.dylib ??? (???) <E03D7C81-A3DA-D44A-A88A-DDBB98AF910B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff804f7000 - 0x7fff8050dfe7 com.apple.MultitouchSupport.framework 207.11 (207.11) <8233CE71-6F8D-8B3C-A0E1-E123F6406163> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff8050e000 - 0x7fff805ebfff com.apple.vImage 4.1 (4.1) <C3F44AA9-6F71-0684-2686-D3BBC903F020> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff805ec000 - 0x7fff807aafff libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <4274FC73-A257-3A56-4293-5968F3428854> /usr/lib/libicucore.A.dylib
0x7fff807ab000 - 0x7fff80adffef com.apple.CoreServices.CarbonCore 861.39 (861.39) <1386A24D-DD15-5903-057E-4A224FAF580B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff80ae0000 - 0x7fff80bc5fef com.apple.DesktopServices 1.5.11 (1.5.11) <39FAA3D2-6863-B5AB-AED9-92D878EA2438> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff80c02000 - 0x7fff80c25fff com.apple.opencl 12.3.6 (12.3.6) <42FA5783-EB80-1168-4015-B8C68F55842F> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff80c26000 - 0x7fff80d3dfef libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <1B27AFDD-DF87-2009-170E-C129E1572E8B> /usr/lib/libxml2.2.dylib
0x7fff80d3e000 - 0x7fff80eb5fe7 com.apple.CoreFoundation 6.6.5 (550.43) <31A1C118-AD96-0A11-8BDF-BD55B9940EDC> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff80fd4000 - 0x7fff81417fef libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <0CC61C98-FF51-67B3-F3D8-C5E430C201A9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff81418000 - 0x7fff81440fff com.apple.DictionaryServices 1.1.2 (1.1.2) <E9269069-93FA-2B71-F9BA-FDDD23C4A65E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff814b4000 - 0x7fff814c8fff libGL.dylib ??? (???) <2ECE3B0F-39E1-3938-BF27-7205C6D0358B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff814c9000 - 0x7fff8150afef com.apple.QD 3.36 (???) <5DC41E81-32C9-65B2-5528-B33E934D5BB4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff81650000 - 0x7fff81699fef libGLU.dylib ??? (???) <1C050088-4AB2-2BC2-62E6-C969F925A945> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff8169a000 - 0x7fff8169ffff libGFXShared.dylib ??? (???) <1D0D3531-9561-632C-D620-1A8652BEF5BC> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff816a3000 - 0x7fff8209dff7 com.apple.AppKit 6.6.8 (1038.36) <4CFBE04C-8FB3-B0EA-8DDB-7E7D10E9D251> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff8209e000 - 0x7fff820bbff7 libPng.dylib ??? (???) <6D8E515B-E0A2-2BA1-9CAC-8CB8A8B35879> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff820e0000 - 0x7fff820effef com.apple.opengl 1.6.13 (1.6.13) <516098B3-4517-8A55-64BB-195CDAA5334D> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff820f0000 - 0x7fff8215afe7 libvMisc.dylib 268.0.1 (compatibility 1.0.0) <AF0EA96D-000F-8C12-B952-CB7E00566E08> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff8215b000 - 0x7fff82162fff com.apple.OpenDirectory 10.6 (10.6) <4FF6AD25-0916-B21C-9E88-2CC42D90EAC7> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff82163000 - 0x7fff821b8ff7 com.apple.framework.familycontrols 2.0.2 (2020) <8807EB96-D12D-8601-2E74-25784A0DE4FF> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x7fff821b9000 - 0x7fff8227afef com.apple.ColorSync 4.6.6 (4.6.6) <BB2C5813-C61D-3CBA-A8F7-0E59E46EBEE8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff8227b000 - 0x7fff82977ff7 com.apple.CoreGraphics 1.545.0 (???) <58D597B1-EB3B-710E-0B8C-EC114D54E11B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff82bda000 - 0x7fff82be9fff com.apple.NetFS 3.2.2 (3.2.2) <7CCBD70E-BF31-A7A7-DB98-230687773145> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff82bea000 - 0x7fff82ca7fff com.apple.CoreServices.OSServices 359.2 (359.2) <BBB8888E-18DE-5D09-3C3A-F4C029EC7886> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff82ca8000 - 0x7fff82cd9fff libGLImage.dylib ??? (???) <7F102A07-E4FB-9F52-B2F6-4E2D2383CA13> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff82cda000 - 0x7fff82cffff7 com.apple.CoreVideo 1.6.2 (45.6) <E138C8E7-3CB6-55A9-0A2C-B73FE63EA288> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff82fad000 - 0x7fff82ff5ff7 libvDSP.dylib 268.0.1 (compatibility 1.0.0) <98FC4457-F405-0262-00F7-56119CA107B6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff82ff6000 - 0x7fff8327fff7 com.apple.security 6.1.2 (55002) <4419AFFC-DAE7-873E-6A7D-5C9A5A4497A6> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff833cb000 - 0x7fff833ddfe7 libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <76B83C8D-8EFE-4467-0F75-275648AFED97> /usr/lib/libsasl2.2.dylib
0x7fff8388a000 - 0x7fff83940ff7 libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <03140531-3B2D-1EBA-DA7F-E12CC8F63969> /usr/lib/libobjc.A.dylib
0x7fff839bf000 - 0x7fff839c3ff7 libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <95718673-FEEE-B6ED-B127-BCDBDB60D4E5> /usr/lib/system/libmathCommon.A.dylib
0x7fff83a08000 - 0x7fff83a09fff liblangid.dylib ??? (???) <EA4D1607-2BD5-2EE2-2A3B-632EEE5A444D> /usr/lib/liblangid.dylib
0x7fff83a0a000 - 0x7fff83a8fff7 com.apple.print.framework.PrintCore 6.3 (312.7) <CDFE82DD-D811-A091-179F-6E76069B432D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff83ff9000 - 0x7fff8403afef com.apple.CoreMedia 0.484.52 (484.52) <3F868AF8-1089-10C3-DCEB-565690FD9742> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff84cca000 - 0x7fff84d0ffff com.apple.CoreMediaIOServices 140.0 (1496) <D93293EB-0B84-E97D-E78C-9FE8D48AF58E> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/CoreMediaIOServices
0x7fff84d10000 - 0x7fff84d9cfef SecurityFoundation ??? (???) <3F1F2727-C508-3630-E2C1-38361841FCE4> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff84d9d000 - 0x7fff84edbfff com.apple.CoreData 102.1 (251) <9DFE798D-AA52-6A9A-924A-DA73CB94D81A> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff84edc000 - 0x7fff84eddff7 com.apple.audio.units.AudioUnit 1.6.7 (1.6.7) <53299948-2554-0F8F-7501-04B34E49F6CF> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff85126000 - 0x7fff85126ff7 com.apple.CoreServices 44 (44) <DC7400FB-851E-7B8A-5BF6-6F50094302FB> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff8515b000 - 0x7fff8522ffe7 com.apple.CFNetwork 454.12.4 (454.12.4) <C83E2BA1-1818-B3E8-5334-860AD21D1C80> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff85230000 - 0x7fff853eeff7 com.apple.ImageIO.framework 3.0.4 (3.0.4) <0A4F51A1-4502-767B-8A4E-F14C6214EF88> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff853ef000 - 0x7fff8548ffff com.apple.LaunchServices 362.3 (362.3) <B90B7C31-FEF8-3C26-BFB3-D8A48BD2C0DA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff85490000 - 0x7fff85c9afe7 libBLAS.dylib 219.0.0 (compatibility 1.0.0) <FC941ECB-71D0-FAE3-DCBF-C5A619E594B8> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff864f5000 - 0x7fff8652ffff libcups.2.dylib 2.8.0 (compatibility 2.0.0) <539EBFDD-96D6-FB07-B128-40232C408757> /usr/lib/libcups.2.dylib
0x7fff86729000 - 0x7fff8672bfff libRadiance.dylib ??? (???) <A9DB4D5D-4072-971B-DEF6-DDE645F415EA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff8672c000 - 0x7fff8679dff7 com.apple.AppleVAFramework 4.10.26 (4.10.26) <28C1B366-DF2B-111B-1863-0713B105D930> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff867b9000 - 0x7fff867b9ff7 com.apple.Cocoa 6.6 (???) <68B0BE46-6E24-C96F-B341-054CF9E8F3B6> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff86804000 - 0x7fff86804ff7 com.apple.ApplicationServices 38 (38) <10A0B9E9-4988-03D4-FC56-DDE231A02C63> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff86809000 - 0x7fff8693efff com.apple.audio.toolbox.AudioToolbox 1.6.7 (1.6.7) <E5D7DBDB-6DDF-E6F9-C71C-86F4520EE5A3> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff8693f000 - 0x7fff869cffff com.apple.SearchKit 1.3.0 (1.3.0) <4175DC31-1506-228A-08FD-C704AC9DF642> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff869d5000 - 0x7fff869fcff7 libJPEG.dylib ??? (???) <46A413EA-4FD1-A050-2EF0-6279F3EAD581> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff86a2d000 - 0x7fff86d2bfff com.apple.HIToolbox 1.6.5 (???) <AD1C18F6-51CB-7E39-35DD-F16B1EB978A8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff86d2c000 - 0x7fff86de1fe7 com.apple.ink.framework 1.3.3 (107) <8C36373C-5473-3A6A-4972-BC29D504250F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff86de2000 - 0x7fff8717ffe7 com.apple.QuartzCore 1.6.3 (227.37) <16DFF6CD-EA58-CE62-A1D7-5F6CE3D066DD> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff87313000 - 0x7fff87366ff7 com.apple.HIServices 1.8.3 (???) <F6E0C7A7-C11D-0096-4DDA-2C77793AA6CD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff87367000 - 0x7fff873b1ff7 com.apple.Metadata 10.6.3 (507.15) <2EF19055-D7AE-4D77-E589-7B71B0BC1E59> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff873cb000 - 0x7fff873ccff7 com.apple.TrustEvaluationAgent 1.1 (1) <5952A9FA-BC2B-16EF-91A7-43902A5C07B6> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fff873cd000 - 0x7fff874e7fef libGLProgrammability.dylib ??? (???) <8A4B86E3-0FA7-8684-2EF2-C5F8079428DB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x7fff87584000 - 0x7fff87598ff7 com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <621B7415-A0B9-07A7-F313-36BEEDD7B132> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff8759b000 - 0x7fff876c3ff7 com.apple.MediaToolbox 0.484.52 (484.52) <F03DAC32-79DB-EA5A-9B8D-CB288AF91A56> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff876c4000 - 0x7fff87713fef libTIFF.dylib ??? (???) <1E2593D1-A7F6-84C6-DF8F-0B46AE445926> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff87a58000 - 0x7fff87a58ff7 com.apple.Accelerate 1.6 (Accelerate 1.6) <15DF8B4A-96B2-CB4E-368D-DEC7DF6B62BB> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff87a59000 - 0x7fff87af3fe7 com.apple.ApplicationServices.ATS 275.16 (???) <4B70A2FC-1902-5F27-5C3B-5C78C283C6EA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff87ce5000 - 0x7fff87d20fff com.apple.AE 496.5 (496.5) <208DF391-4DE6-81ED-C697-14A2930D1BC6> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff87d21000 - 0x7fff87d36ff7 com.apple.LangAnalysis 1.6.6 (1.6.6) <1AE1FE8F-2204-4410-C94E-0E93B003BEDA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff87dc0000 - 0x7fff87de0ff7 com.apple.DirectoryService.Framework 3.6 (621.12) <A4685F06-5881-35F5-764D-C380304C1CE8> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x7fff87dee000 - 0x7fff882f4ff7 com.apple.VideoToolbox 0.484.52 (484.52) <FA1B8197-8F5F-73CB-A9A1-49E0FB49CF51> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff882f5000 - 0x7fff88577fe7 com.apple.Foundation 6.6.7 (751.62) <6F2A5BBF-6990-D561-2928-AD61E94036D9> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff88761000 - 0x7fff88767ff7 com.apple.CommerceCore 1.0 (9.1) <3691E9BA-BCF4-98C7-EFEC-78DA6825004E> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
0x7fff887dd000 - 0x7fff887e2fff libGIF.dylib ??? (???) <201B8077-B5CC-11AA-E1B0-1D057ABE416A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff8883b000 - 0x7fff8885cfff libresolv.9.dylib 41.0.0 (compatibility 1.0.0) <9F322F47-0584-CB7D-5B73-9EBD670851CD> /usr/lib/libresolv.9.dylib
0x7fff8885d000 - 0x7fff88863ff7 IOSurface ??? (???) <8E302BB2-0704-C6AB-BD2F-C2A6C6A2E2C3> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff88987000 - 0x7fff88a48fff libFontParser.dylib ??? (???) <A00BB0A7-E46C-1D07-1391-194745566C7E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fff88a87000 - 0x7fff88a98ff7 libz.1.dylib 1.2.3 (compatibility 1.0.0) <97019C74-161A-3488-41EC-A6CA8738418C> /usr/lib/libz.1.dylib
0x7fff88a99000 - 0x7fff88b18fe7 com.apple.audio.CoreAudio 3.2.6 (3.2.6) <79E256EB-43F1-C7AA-6436-124A4FFB02D0> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff88b19000 - 0x7fff88bc9fff edu.mit.Kerberos 6.5.11 (6.5.11) <085D80F5-C9DC-E252-C21B-03295E660C91> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff88cd1000 - 0x7fff88ceafff com.apple.CFOpenDirectory 10.6 (10.6) <401557B1-C6D1-7E1A-0D7E-941715C37BFA> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff88da9000 - 0x7fff88e26fef libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <35ECA411-2C08-FD7D-11B1-1B7A04921A5C> /usr/lib/libstdc++.6.dylib
0x7fff89126000 - 0x7fff8916dff7 com.apple.coreui 2 (114) <923E33CC-83FC-7D35-5603-FB8F348EE34B> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff8916e000 - 0x7fff8917bfe7 libCSync.A.dylib 545.0.0 (compatibility 64.0.0) <1C35FA50-9C70-48DC-9E8D-2054F7A266B1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x7fff891ba000 - 0x7fff89273fff libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <2C5ED312-E646-9ADE-73A9-6199A2A43150> /usr/lib/libsqlite3.dylib
0x7fff892dd000 - 0x7fff892e3ff7 com.apple.DiskArbitration 2.3 (2.3) <857F6E43-1EF4-7D53-351B-10DE0A8F992A> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff89367000 - 0x7fff89375ff7 libkxld.dylib ??? (???) <8145A534-95CC-9F3C-B78B-AC9898F38C6F> /usr/lib/system/libkxld.dylib
0x7fff89376000 - 0x7fff89381ff7 com.apple.speech.recognition.framework 3.11.1 (3.11.1) <3D65E89B-FFC6-4AAF-D5CC-104F967C8131> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff89382000 - 0x7fff893d1ff7 com.apple.DirectoryService.PasswordServerFramework 6.1 (6.1) <0731C40D-71EF-B417-C83B-54C3527A36EA> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
0x7fff893e0000 - 0x7fff89421fff com.apple.SystemConfiguration 1.10.8 (1.10.2) <78D48D27-A9C4-62CA-2803-D0BBED82855A> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff89432000 - 0x7fff89432ff7 com.apple.vecLib 3.6 (vecLib 3.6) <96FB6BAD-5568-C4E0-6FA7-02791A58B584> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff89433000 - 0x7fff894b1ff7 com.apple.CoreText 151.10 (???) <54961997-55D8-DC0F-2634-674E452D5A8E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff89537000 - 0x7fff89656fe7 libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <14115D29-432B-CF02-6B24-A60CC533A09E> /usr/lib/libcrypto.0.9.8.dylib
0x7fff896d4000 - 0x7fff896eafef libbsm.0.dylib ??? (???) <42D3023A-A1F7-4121-6417-FCC6B51B3E90> /usr/lib/libbsm.0.dylib
0x7fff896eb000 - 0x7fff89716ff7 libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <8AB4CA9E-435A-33DA-7041-904BA7FA11D5> /usr/lib/libxslt.1.dylib
0x7fff8975a000 - 0x7fff897a6fff libauto.dylib ??? (???) <F7221B46-DC4F-3153-CE61-7F52C8C293CF> /usr/lib/libauto.dylib
0x7fff897a7000 - 0x7fff89872fff ColorSyncDeprecated.dylib 4.6.0 (compatibility 1.0.0) <E72880D9-3B5D-D086-9266-F4F3C294619F> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
0x7fffffe00000 - 0x7fffffe01fff libSystem.B.dylib ??? (???) <9AB4F1D1-89DC-0E8A-DC8E-A4FE4D69DB69> /usr/lib/libSystem.B.dylib
Version: ??? (???)
Report Version: 6
Thread 1:
Thread 3:
Binary Images:
geposted Mon 30 Apr 12 @ 2:19 am
ANOTHER ONE::
Process: VirtualDJ Pro Full [214]
Path: /Applications/VirtualDJ Pro Full.app/Contents/MacOS/VirtualDJ Pro Full
Identifier: com.atomixproductions.virtualdjprofull
Version: 7.0.5 (7.0.5)
Code Type: X86 (Native)
Parent Process: launchd [90]
Date/Time: 2012-04-27 13:57:31.820 -0700
Report Version: 6
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000008
Crashed Thread: 11
Thread 0: Dispatch queue: com.apple.main-thread
0 com.apple.CoreFoundation 0x9949cd85 CFAllocatorDeallocate + 21
1 com.apple.CoreFoundation 0x994bd0fd __CFBasicHashDrain + 733
2 com.apple.CoreFoundation 0x994a50b1 _CFRelease + 353
3 com.apple.CoreFoundation 0x9951d052 CFRunLoopRemoveObserver + 594
4 com.apple.CoreFoundation 0x9951d381 CFRunLoopObserverInvalidate + 353
5 com.apple.CoreFoundation 0x99518f33 __CFRunLoopDoObservers + 1491
6 com.apple.CoreFoundation 0x994d441a CFRunLoopRunSpecific + 490
7 com.apple.CoreFoundation 0x994d4221 CFRunLoopRunInMode + 97
8 com.apple.HIToolbox 0x96b8be04 RunCurrentEventLoopInMode + 392
9 com.apple.HIToolbox 0x96b8bbb9 ReceiveNextEventCommon + 354
10 com.apple.HIToolbox 0x96d14084 _AcquireNextEvent + 54
11 com.apple.HIToolbox 0x96d09d40 RunApplicationEventLoop + 228
12 ...roductions.virtualdjprofull 0x0013aa0a main + 1226
13 ...roductions.virtualdjprofull 0x00024dfa start + 54
Thread 1: Dispatch queue: com.apple.libdispatch-manager
0 libSystem.B.dylib 0x99b97382 kevent + 10
1 libSystem.B.dylib 0x99b97a9c _dispatch_mgr_invoke + 215
2 libSystem.B.dylib 0x99b96f59 _dispatch_queue_invoke + 163
3 libSystem.B.dylib 0x99b96cfe _dispatch_worker_thread2 + 240
4 libSystem.B.dylib 0x99b96781 _pthread_wqthread + 390
5 libSystem.B.dylib 0x99b965c6 start_wqthread + 30
Thread 2:
0 libSystem.B.dylib 0x99b70b5a semaphore_timedwait_signal_trap + 10
1 libSystem.B.dylib 0x99b9e6e1 _pthread_cond_wait + 1066
2 libSystem.B.dylib 0x99bcd5a8 pthread_cond_timedwait_relative_np + 47
3 ...ple.CoreServices.CarbonCore 0x932fab90 TSWaitOnConditionTimedRelative + 242
4 ...ple.CoreServices.CarbonCore 0x932fa8ce TSWaitOnSemaphoreCommon + 511
5 ...ickTimeComponents.component 0x97949e35 ReadSchedulerThreadEntryPoint + 4698
6 libSystem.B.dylib 0x99b9e259 _pthread_start + 345
7 libSystem.B.dylib 0x99b9e0de thread_start + 34
Thread 3:
4 ...ple.CoreServices.CarbonCore 0x9337d521 MPWaitForEvent + 240
5 ...roductions.virtualdjprofull 0x00123a87 IThread::ThreadProc() + 61
6 ...roductions.virtualdjprofull 0x00123ad8 StaticThreadProc(void*) + 17
7 ...ple.CoreServices.CarbonCore 0x932da54a PrivateMPEntryPoint + 68
8 libSystem.B.dylib 0x99b9e259 _pthread_start + 345
9 libSystem.B.dylib 0x99b9e0de thread_start + 34
Thread 4:
Thread 5:
0 libSystem.B.dylib 0x99b70afa mach_msg_trap + 10
1 libSystem.B.dylib 0x99b71267 mach_msg + 68
2 com.apple.CoreFoundation 0x994d530f __CFRunLoopRun + 2079
3 com.apple.CoreFoundation 0x994d43f4 CFRunLoopRunSpecific + 452
4 com.apple.CoreFoundation 0x994d4221 CFRunLoopRunInMode + 97
5 com.apple.Foundation 0x987aa2c4 +[NSURLConnection(NSURLConnectionReallyInternal) _resourceLoadLoop:] + 329
6 com.apple.Foundation 0x98771564 -[NSThread main] + 45
7 com.apple.Foundation 0x98771514 __NSThread__main__ + 1499
Thread 6:
Thread 7: com.apple.CFSocket.private
0 libSystem.B.dylib 0x99b8fac6 select$DARWIN_EXTSN + 10
1 com.apple.CoreFoundation 0x99514c83 __CFSocketManager + 1091
2 libSystem.B.dylib 0x99b9e259 _pthread_start + 345
3 libSystem.B.dylib 0x99b9e0de thread_start + 34
Thread 8:
2 com.apple.audio.midi.CoreMIDI 0x015f20c1 XServerMachPort::ReceiveMessage(int&, void*, int&) + 155
3 com.apple.audio.midi.CoreMIDI 0x0161097a MIDIProcess::RunMIDIInThread() + 150
4 com.apple.audio.midi.CoreMIDI 0x015f32d9 XThread::RunHelper(void*) + 17
5 com.apple.audio.midi.CoreMIDI 0x015f2ca6 CAPThread::Entry(CAPThread*) + 96
Thread 9:
0 libSystem.B.dylib 0x99b9eaa2 __semwait_signal + 10
1 libSystem.B.dylib 0x99b9e75e _pthread_cond_wait + 1191
2 libSystem.B.dylib 0x99ba03f8 pthread_cond_wait$UNIX2003 + 73
3 ...roductions.virtualdjprofull 0x00638e70 localUpcallThread(void*) + 146
4 libSystem.B.dylib 0x99b9e259 _pthread_start + 345
5 libSystem.B.dylib 0x99b9e0de thread_start + 34
Thread 10:
4 com.apple.CoreFoundation 0x994da334 CFRunLoopRun + 84
5 ...roductions.virtualdjprofull 0x0063822d localDispatchThread(void*) + 457
Thread 11 Crashed:
0 com.yourcompany.SBDJ-Camera 0x1ac18c82 CCamera::OnStart() + 154
1 ...roductions.virtualdjprofull 0x000e8952 CPluginVideoFx::Start() + 58
2 ...roductions.virtualdjprofull 0x00136dae CVideoIddle::Start() + 56
3 ...roductions.virtualdjprofull 0x001342b0 CVideo::Thread() + 1254
4 ...roductions.virtualdjprofull 0x00123a69 IThread::ThreadProc() + 31
5 ...roductions.virtualdjprofull 0x00123ad8 StaticThreadProc(void*) + 17
6 ...ple.CoreServices.CarbonCore 0x932da54a PrivateMPEntryPoint + 68
7 libSystem.B.dylib 0x99b9e259 _pthread_start + 345
8 libSystem.B.dylib 0x99b9e0de thread_start + 34
Thread 12:
5 com.apple.CoreMediaIOServices 0x993cdf15 MIO::DAL::RunLoop::OwnThread(void*) + 157
6 com.apple.CoreMediaIOServices 0x993cfdda CAPThread::Entry(CAPThread*) + 180
Thread 13:
3 ...ple.CoreServices.CarbonCore 0x9330f21e TSWaitOnCondition + 126
4 ...ple.CoreServices.CarbonCore 0x932fab68 TSWaitOnConditionTimedRelative + 202
5 ...ple.CoreServices.CarbonCore 0x9337d232 MPEnterCriticalRegion + 198
6 ...roductions.virtualdjprofull 0x00009579 CThreadSync::Enter() + 33
7 ...roductions.virtualdjprofull 0x00135ae4 CVideoClip1T::FrameToSurface(int) + 164
8 ...roductions.virtualdjprofull 0x00135e56 CVideoClip1T::Thread() + 298
9 ...roductions.virtualdjprofull 0x00123a69 IThread::ThreadProc() + 31
10 ...roductions.virtualdjprofull 0x00123ad8 StaticThreadProc(void*) + 17
11 ...ple.CoreServices.CarbonCore 0x932da54a PrivateMPEntryPoint + 68
12 libSystem.B.dylib 0x99b9e259 _pthread_start + 345
13 libSystem.B.dylib 0x99b9e0de thread_start + 34
Thread 14:
3 com.apple.audio.CoreAudio 0x983dc3ab CAGuard::WaitFor(unsigned long long) + 219
4 com.apple.audio.CoreAudio 0x983df3dd CAGuard::WaitUntil(unsigned long long) + 289
5 com.apple.audio.CoreAudio 0x983dccda HP_IOThread::WorkLoop() + 1892
6 com.apple.audio.CoreAudio 0x983dc571 HP_IOThread::ThreadEntry(HP_IOThread*) + 17
7 com.apple.audio.CoreAudio 0x983dc488 CAPThread::Entry(CAPThread*) + 140
Thread 15:
0 libSystem.B.dylib 0x99b96412 __workq_kernreturn + 10
1 libSystem.B.dylib 0x99b969a8 _pthread_wqthread + 941
2 libSystem.B.dylib 0x99b965c6 start_wqthread + 30
Thread 16:
1 libSystem.B.dylib 0x99bca9c5 nanosleep$UNIX2003 + 188
2 libSystem.B.dylib 0x99bca903 usleep$UNIX2003 + 61
3 com.apple.AppKit 0x98b7ee2d -[NSUIHeartBeat _heartBeatThread:] + 2039
4 com.apple.Foundation 0x98771564 -[NSThread main] + 45
5 com.apple.Foundation 0x98771514 __NSThread__main__ + 1499
Thread 17:
3 com.apple.CoreMediaIOServices 0x993d282b MIOGraph::OneOrMoreInputUnitsAreReadyToBePulled(bool&) + 805
4 com.apple.CoreMediaIOServices 0x993d343b MIOGraph::DoWork(unsigned long) + 353
5 com.apple.CoreMediaIOServices 0x993e484f MIO::Thread::QueuedTWorkThread<unsigned long>::DoWork() + 169
6 com.apple.CoreMediaIOServices 0x993f0c7e MIO::Thread::SignaledThread::ThreadLoop() + 294
7 com.apple.CoreMediaIOServices 0x993f1012 MIO::Thread::SignaledThread::WorkQueuedThreadCallback(void*) + 206
Thread 18:
5 com.apple.mio.DAL.VDC_4 0x22721f69 0x2271a000 + 32617
Thread 11 crashed with X86 Thread State (32-bit):
eax: 0x00000000 ebx: 0x1ac18bf6 ecx: 0x00000001 edx: 0x00000000
edi: 0x1a942d20 esi: 0x00000000 ebp: 0xb099ec88 esp: 0xb099ec20
ss: 0x0000001f efl: 0x00010286 eip: 0x1ac18c82 cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x0000001f gs: 0x00000037
cr2: 0x00000008
Binary Images:
0x1000 - 0xa02fe3 +com.atomixproductions.virtualdjprofull 7.0.5 (7.0.5) <7456B0CE-1E67-2709-9900-25ED83C80C01> /Applications/VirtualDJ Pro Full.app/Contents/MacOS/VirtualDJ Pro Full
0x14e7000 - 0x159cfe7 libcrypto.0.9.7.dylib 0.9.7 (compatibility 0.9.7) <AACC86C0-86B4-B1A7-003F-2A0AF68973A2> /usr/lib/libcrypto.0.9.7.dylib
0x15e2000 - 0x162effb com.apple.audio.midi.CoreMIDI 1.7.1 (42) <FB4D4B64-6ABB-679E-3AA8-21DE9062B4C1> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x250c000 - 0x2510ff3 com.apple.audio.AudioIPCPlugIn 1.1.6 (1.1.6) <E9CB576C-283B-1DB2-0C69-E7C914BD7922> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
0x2517000 - 0x2518ff7 ATSHI.dylib ??? (???) <8791C226-0725-314F-5897-BAAE57CA1EEE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/ATSHI.dylib
0x2528000 - 0x252eff7 com.apple.audio.AppleHDAHALPlugIn 2.0.5 (2.0.5f14) <38E3C1A4-84E4-C105-B55F-8FC4C154036D> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x2552000 - 0x2552ff7 libmx.A.dylib 315.0.0 (compatibility 1.0.0) <01401BF8-3FC7-19CF-ACCE-0F292BFD2F25> /usr/lib/libmx.A.dylib
0x2555000 - 0x2570fef com.apple.AppleIntermediateCodec 1.3.2 (153) <D42634C1-8BDA-31ED-5216-13CB19BA7D1B> /Library/QuickTime/AppleIntermediateCodec.component/Contents/MacOS/AppleIntermediateCodec
0x2591000 - 0x25e6fef com.apple.AppleProResDecoder 2.0 (223) <793BA98A-2E7D-1C39-998D-805B60034DF4> /System/Library/QuickTime/AppleProResDecoder.component/Contents/MacOS/AppleProResDecoder
0x261e000 - 0x2623fff com.apple.AppleMPEG2Codec 1.0.2 (220.1) <CE69C1D8-796C-753F-AD3C-F1CC2B8C0AAD> /Library/QuickTime/AppleMPEG2Codec.component/Contents/MacOS/AppleMPEG2Codec
0x277f000 - 0x27bbfe3 com.apple.QuickTimeFireWireDV.component 7.6.6 (1783) <9D242689-A430-BD2D-3CF0-3AC6F6CCD1D9> /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacOS/QuickTimeFireWireDV
0x27c7000 - 0x27e0fe7 com.apple.applepixletvideo 1.2.19 (1.2d19) <4A68731C-8071-6CF5-012C-40F00CD1333A> /System/Library/QuickTime/ApplePixletVideo.component/Contents/MacOS/ApplePixletVideo
0x27f3000 - 0x27f6fff +com.atomixprod.beatgrid 1.0 (1.0) /Users/anwaarhines/Documents/VirtualDJ/Plugins/SoundEffect/BeatGrid.bundle/Contents/MacOS/BeatGrid
0x27fb000 - 0x27fcfff com.apple.carbonbundletemplate 1.0 (1.0) /Users/anwaarhines/Documents/VirtualDJ/Plugins/SoundEffect/FlippinDouble.bundle/Contents/MacOS/FlippinDouble
0x17ba4000 - 0x17c1efef com.apple.AppleVAH264HW.component 2.0 (1.0) <4AF4C42D-7DE3-0C08-82A4-C3B970D3914E> /System/Library/QuickTime/AppleVAH264HW.component/Contents/MacOS/AppleVAH264HW
0x1a6a7000 - 0x1a6b1ff7 com.apple.IOFWDVComponents 1.9.9 (1.9.9) <5B4E7BD7-EF5A-2F5C-DF8E-3D4A7B59F779> /System/Library/Components/IOFWDVComponents.component/Contents/MacOS/IOFWDVComponents
0x1ab3f000 - 0x1ab41fff +com.TexZK.VirtualDJSoundPlugin.Granular 1.0 (1.0) /Users/anwaarhines/Documents/VirtualDJ/Plugins/SoundEffect/Granular.bundle/Contents/MacOS/Granular
0x1ac0d000 - 0x1aefaffb +com.yourcompany.SBDJ-Camera 1.0 (1) <440FE60A-4776-259B-3903-E53F3DCD6E36> /Users/anwaarhines/Documents/VirtualDJ/Plugins/VideoEffect/SBDJ Camera.bundle/Contents/MacOS/SBDJ Camera
0x1b0d3000 - 0x1b24cff7 GLEngine ??? (???) <64C74F67-44B5-7DEF-CCA6-C8A9FF9BB60A> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
0x1b27e000 - 0x1b683fe7 libclh.dylib 3.1.1 C (3.1.1) <15AD52DD-FC3F-305E-5C31-699329E8FDE1> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib
0x1b6a7000 - 0x1b6cbfe7 GLRendererFloat ??? (???) <AD081A9B-1424-1F17-3C68-9803EBA37E8D> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFloat
0x1c6ea000 - 0x1c6f3fff +com.yourcompany.SBDJ_Strips ??? (1.0) <222EF553-3EF2-2D11-3CE3-098B9BE344F8> /Users/anwaarhines/Documents/VirtualDJ/Plugins/VideoTransition/SBDJ Strips.bundle/Contents/MacOS/SBDJ Strips
0x1c6fa000 - 0x1c6fcfff +com.djcel.VirtualDJSoundPlugin.FlangerHQ 2.2 (2.2) /Users/anwaarhines/Documents/VirtualDJ/Plugins/SoundEffect/FlangerHQ.bundle/Contents/MacOS/FlangerHQ
0x1ef47000 - 0x1ef48fff com.apple.carbonbundletemplate 1.0 (1.0) /Users/anwaarhines/Documents/VirtualDJ/Plugins/SoundEffect/Cut.bundle/Contents/MacOS/Cut
0x1ef4c000 - 0x1ef4dfff com.apple.carbonbundletemplate 1.0 (1.0) /Users/anwaarhines/Documents/VirtualDJ/Plugins/SoundEffect/Flanger.bundle/Contents/MacOS/Flanger
0x1f822000 - 0x1f863fe3 com.apple.audio.SoundManager.Components 3.9.4 (3.9.4) <AD66647C-03A9-EBAF-6FFC-E5A631F4D6BE> /System/Library/Components/SoundManagerComponents.component/Contents/MacOS/SoundManagerComponents
0x1f86a000 - 0x1fa50fef com.apple.audio.codecs.Components 2.0.3 (2.0.3) <8DA1B494-CD97-D4CC-3D5D-FACFAAE9D968> /System/Library/Components/AudioCodecs.component/Contents/MacOS/AudioCodecs
0x202b2000 - 0x202cfff7 com.apple.IOFireWireLib 4.2.6 (4.2.6) <D1D1F91F-2A48-8B86-1CB2-EC849BDB9808> /System/Library/Extensions/IOFireWireFamily.kext/Contents/PlugIns/IOFireWireLib.plugin/Contents/MacOS/IOFireWireLib
0x2245b000 - 0x22497ff3 com.apple.DP.ScreenInputDevice 15.0 (15.0) <423039F0-E590-0254-D767-C04F1E2287AA> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Resources/AppleScreenInputDevice.plugin/Contents/MacOS/AppleScreenInputDevice
0x2271a000 - 0x22743feb com.apple.mio.DAL.VDC_4 140.0 (1496) <B0C3DA44-D183-F32E-44DB-13D828580C5E> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Resources/VDC.plugin/Contents/MacOS/VDC
0x2274c000 - 0x228fafe3 com.apple.TundraUnits 140.0 (1496) <51A20C84-A2F6-4F40-2E33-D5AB9E0CE068> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Resources/TundraUnits.bundle/Contents/MacOS/TundraUnits
0x2291d000 - 0x22950ff3 com.apple.FWAVC 130.46 (46) <2F2CD20F-5B9E-911A-7EA8-40D016A6C23C> /System/Library/PrivateFrameworks/FWAVC.framework/Versions/A/FWAVC
0x22965000 - 0x2298fffb com.apple.QuickTimeIIDCDigitizer 7.6.6 (1783) <8608D7B6-2D9C-5DEF-DDC8-FE630A598888> /System/Library/QuickTime/QuickTimeIIDCDigitizer.component/Contents/MacOS/QuickTimeIIDCDigitizer
0x70000000 - 0x700cbfff com.apple.audio.units.Components 1.6.5 (1.6.5) <E50D0989-0609-EAF7-3B3B-B10D7847BAA5> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
0x8f0c6000 - 0x8f811fff com.apple.GeForceGLDriver 1.6.36 (6.3.6) <3BB341B6-11A7-38AD-10A3-F89506FD40D4> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver
0x8fe00000 - 0x8fe4163b dyld 132.1 (???) <4CDE4F04-0DD6-224E-ACE5-3C06E169A801> /usr/lib/dyld
0x9005b000 - 0x9008bff7 com.apple.MeshKit 1.1 (49.2) <5A74D1A4-4B97-FE39-4F4D-E0B80F0ADD87> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/MeshKit
0x90128000 - 0x901e1fe7 libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <52438E77-55D1-C231-1936-76F1369518E4> /usr/lib/libsqlite3.dylib
0x90218000 - 0x90242ff7 com.apple.shortcut 1.1 (1.1) <B0514FA9-7CAE-AD94-93CA-7B2A2C5F7B8A> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x90296000 - 0x90478fff com.apple.imageKit 2.0.3 (1.0) <6E557757-26F7-7941-8AE7-046EC1871F50> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x90479000 - 0x9088fff7 libBLAS.dylib 219.0.0 (compatibility 1.0.0) <C4FB303A-DB4D-F9E8-181C-129585E59603> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x90890000 - 0x9093eff3 com.apple.ink.framework 1.3.3 (107) <233A981E-A2F9-56FB-8BDE-C2DEC3F20784> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x9093f000 - 0x909ebfe7 com.apple.CFNetwork 454.12.4 (454.12.4) <DEDCD006-389F-967F-3405-EDF541F406D7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x909ec000 - 0x90a49ff7 com.apple.framework.IOKit 2.0 (???) <3DABAB9C-4949-F441-B077-0498F8E47A35> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x90a4a000 - 0x90a8dff7 libGLU.dylib ??? (???) <FB26DD53-03F4-A7D7-8804-EBC5B3B37FA3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x90a8e000 - 0x90b68fff com.apple.DesktopServices 1.5.11 (1.5.11) <800F2040-9211-81A7-B438-7712BF51DEE3> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x90b69000 - 0x90b6dff7 libGIF.dylib ??? (???) <2123645B-AC89-C4E2-8757-85834CAE3DD2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x90b6e000 - 0x90b86ff7 com.apple.CFOpenDirectory 10.6 (10.6) <D1CF5881-0AF7-D164-4156-9E9067B7FA37> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x90b87000 - 0x90ba3fe3 com.apple.openscripting 1.3.1 (???) <2A748037-D1C0-6D47-2C4A-0562AF799AC9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x90c1c000 - 0x90c2aff7 com.apple.opengl 1.6.13 (1.6.13) <025A905D-C1A3-B24A-1585-37C328D77148> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x90c2b000 - 0x90c32ff3 com.apple.print.framework.Print 6.1 (237.1) <F5AAE53D-5530-9004-A9E3-2C1690C5328E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x90c3f000 - 0x91090fef com.apple.RawCamera.bundle 3.7.1 (570) <AF94D180-5E0F-10DF-0CB2-FD8EDB110FA2> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x91091000 - 0x9109bff7 com.apple.HelpData 2.0.5 (34.1.1) <A9CF754F-B254-5D40-B8B5-F35414DFD875> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x910a9000 - 0x91141fe7 edu.mit.Kerberos 6.5.11 (6.5.11) <F36DB665-A88B-7F5B-6244-6A2E7FFFF668> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x91195000 - 0x91810ff7 com.apple.CoreAUC 6.11.03 (6.11.03) <42B31B0F-18F9-29D2-A67C-7B81A47F6D67> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x9184a000 - 0x91855ff7 libGL.dylib ??? (???) <3E34468F-E9A7-8EFB-FF66-5204BD5B4E21> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x9187d000 - 0x918b0ff7 com.apple.AE 496.5 (496.5) <BF9673D5-2419-7120-26A3-83D264C75222> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x91a62000 - 0x91a74ff7 com.apple.MultitouchSupport.framework 207.11 (207.11) <6FF4F2D6-B8CD-AE13-56CB-17437EE5B741> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x91a75000 - 0x91c53fe3 libType1Scaler.dylib ??? (???) <97A2DBFA-C50B-266C-E63A-D6644F3B737C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libType1Scaler.dylib
0x91c8d000 - 0x91c91ff7 IOSurface ??? (???) <89D859B7-A26A-A5AB-8401-FC1E01AC7A60> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x91c92000 - 0x91c93ff7 com.apple.TrustEvaluationAgent 1.1 (1) <2D970A9B-77E8-EDC0-BEC6-7580D78B2843> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x91c94000 - 0x91c9dff7 com.apple.DiskArbitration 2.3 (2.3) <E9C40767-DA6A-6CCB-8B00-2D5706753000> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x91c9e000 - 0x91ca0ff7 com.apple.QuickTimeH264.component 7.6.6 (1783) /System/Library/QuickTime/QuickTimeH264.component/Contents/MacOS/QuickTimeH264
0x91ca1000 - 0x9200cff7 com.apple.QuartzCore 1.6.3 (227.37) <E323A5CC-499E-CA9E-9BC3-537231449CAA> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x9200d000 - 0x9200eff7 com.apple.MonitorPanelFramework 1.3.0 (1.3.0) <0EC4EEFF-477E-908E-6F21-ED2C973846A4> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel
0x9200f000 - 0x92031fef com.apple.DirectoryService.Framework 3.6 (621.12) <A4A47C88-138C-A237-88A5-877E5CAB4494> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x92032000 - 0x920e2fe3 com.apple.QuickTimeImporters.component 7.6.6 (1783) <E0BF3843-1044-F371-AB6F-423C5E9E417B> /System/Library/QuickTime/QuickTimeImporters.component/Contents/MacOS/QuickTimeImporters
0x920e3000 - 0x92124ff7 libRIP.A.dylib 545.0.0 (compatibility 64.0.0) <80998F66-0AD7-AD12-B9AF-3E8D2CE6DE05> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x92125000 - 0x92253fe7 com.apple.CoreData 102.1 (251) <87FE6861-F2D6-773D-ED45-345272E56463> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x92254000 - 0x92689ff7 libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <5E2D2283-57DE-9A49-1DB0-CD027FEFA6C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x9268a000 - 0x92755fef com.apple.CoreServices.OSServices 359.2 (359.2) <7C16D9C8-6F41-5754-17F7-2659D9DD9579> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x92756000 - 0x92858fef com.apple.MeshKitIO 1.1 (49.2) <D0401AC5-1F92-2BBB-EBAB-58EDD3BA61B9> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitIO.framework/Versions/A/MeshKitIO
0x92859000 - 0x9285ffff com.apple.CommonPanels 1.2.4 (91) <2438AF5D-067B-B9FD-1248-2C9987F360BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x932b4000 - 0x935d4ff3 com.apple.CoreServices.CarbonCore 861.39 (861.39) <5C59805C-AF39-9010-B8B5-D673C9C38538> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x935d5000 - 0x935d8ff7 libCoreVMClient.dylib ??? (???) <F58BDFC1-7408-53C8-0B08-48BA2F25CA43> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x935d9000 - 0x935e5ff7 libkxld.dylib ??? (???) <9A441C48-2D18-E716-5F38-CBEAE6A0BB3E> /usr/lib/system/libkxld.dylib
0x935e6000 - 0x9362ffe7 libTIFF.dylib ??? (???) <579DC328-567D-A74C-4BCE-1D1C729E3F6D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x93630000 - 0x93654ff7 libJPEG.dylib ??? (???) <EA97DEC5-6E16-B51C-BF55-F6E8D23526AD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x93696000 - 0x9369bff7 com.apple.OpenDirectory 10.6 (10.6) <0603680A-A002-D294-DE83-0D028C6BE884> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x9369c000 - 0x93700ffb com.apple.htmlrendering 72 (1.1.4) <4D451A35-FAB6-1288-71F6-F24A4B6E2371> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x93701000 - 0x93770ff7 libvMisc.dylib 268.0.1 (compatibility 1.0.0) <595A5539-9F54-63E6-7AAC-C04E1574B050> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x93771000 - 0x93773ff7 libRadiance.dylib ??? (???) <5920EB69-8D7F-5EFD-70AD-590FCB5C9E6C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x93774000 - 0x93774ff7 com.apple.quartzframework 1.5 (1.5) <4EE8095D-5E47-1EB6-3A8A-6ECE3BEC8647> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x93775000 - 0x93775ff7 com.apple.Cocoa 6.6 (???) <EA27B428-5904-B00B-397A-185588698BCC> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x937ab000 - 0x93848fe3 com.apple.LaunchServices 362.3 (362.3) <15B47388-16C8-97DA-EEBB-1709E136169E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x93849000 - 0x9386afe7 com.apple.opencl 12.3.6 (12.3.6) <B4104B80-1CB3-191C-AFD3-697843C6BCFF> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x93910000 - 0x93b0eff3 com.apple.JavaScriptCore 6533.20 (6533.20.20) <011E271D-4CA4-FFB0-2EDD-13C31C239899> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x93b0f000 - 0x93b21ff7 com.apple.CoreMediaAuthoring 0.706 (706) <81D68084-D7BD-E52E-9B1C-C8EC0FCECE3C> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
0x93b22000 - 0x93b53ff7 libGLImage.dylib ??? (???) <0EE86397-A867-0BBA-E5B1-B800E43FC5CF> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x93b54000 - 0x93bbefe7 libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
0x93bbf000 - 0x93bc9fe7 com.apple.audio.SoundManager 3.9.3 (3.9.3) <5F494955-7290-2D91-DA94-44B590191771> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x93bca000 - 0x93c0eff3 com.apple.coreui 2 (114) <2234855E-3BED-717F-0BFA-D1A289ECDBDA> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x93c0f000 - 0x93c0fff7 com.apple.vecLib 3.6 (vecLib 3.6) <FF4DC8B6-0AB0-DEE8-ADA8-7B57645A1F36> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x93e18000 - 0x93e55ff7 com.apple.SystemConfiguration 1.10.8 (1.10.2) <50E4D49B-4F61-446F-1C21-1B2BA814713D> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x93e56000 - 0x93ed6feb com.apple.SearchKit 1.3.0 (1.3.0) <9E18AEA5-F4B4-8BE5-EEA9-818FC4F46FD9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x93ed7000 - 0x93ef2ff7 libPng.dylib ??? (???) <25DF2360-BFD3-0165-51AC-0BDAF7899DEC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x93ef3000 - 0x93fabfeb libFontParser.dylib ??? (???) <D57D3834-9395-FD58-092A-49B3708E8C89> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x93fac000 - 0x940e9fe7 com.apple.audio.toolbox.AudioToolbox 1.6.7 (1.6.7) <2D31CC6F-32CC-72FF-34EC-AB40CEE496A7> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x940ea000 - 0x94192ffb com.apple.QD 3.36 (???) <FA2785A4-BB69-DCB4-3BA3-7C89A82CAB41> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x9419a000 - 0x941bafe7 libresolv.9.dylib 41.0.0 (compatibility 1.0.0) <BF7FF2F6-5FD3-D78F-77BC-9E2CB2A5E309> /usr/lib/libresolv.9.dylib
0x941dc000 - 0x94212fff libtidy.A.dylib ??? (???) <0FD72C68-4803-4C5B-3A63-05D7394BFD71> /usr/lib/libtidy.A.dylib
0x94213000 - 0x9423bff7 libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <315D97C2-4E1F-A95F-A759-4A3FA5639E75> /usr/lib/libxslt.1.dylib
0x9423c000 - 0x94276ff7 libcups.2.dylib 2.8.0 (compatibility 2.0.0) <6875335E-0993-0D77-4E80-41763A8477CF> /usr/lib/libcups.2.dylib
0x94277000 - 0x94309fe7 com.apple.print.framework.PrintCore 6.3 (312.7) <7410D1B2-655D-68DA-D4B9-2C65747B6817> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x9430a000 - 0x9436bfe7 com.apple.CoreText 151.10 (???) <5C2DEFBE-D54B-4DC7-D456-9ED02880BE98> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x944af000 - 0x944b6ff7 com.apple.agl 3.0.12 (AGL-3.0.12) <A5FF7623-9F55-0364-AD9B-42CF13C677C1> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x944b7000 - 0x944b7ff7 liblangid.dylib ??? (???) <B99607FC-5646-32C8-2C16-AFB5EA9097C2> /usr/lib/liblangid.dylib
0x944d6000 - 0x9452cff7 com.apple.MeshKitRuntime 1.1 (49.2) <CB9F38B1-E107-EA62-EDFF-02EE79F6D1A5> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitRuntime.framework/Versions/A/MeshKitRuntime
0x9452d000 - 0x94560fff libTrueTypeScaler.dylib ??? (???) <0F04DAC3-829A-FA1B-E9D0-1E9505713C5C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x94561000 - 0x94576fff com.apple.ImageCapture 6.1 (6.1) <B909459A-EAC9-A7C8-F2A9-CD757CDB59E8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x94577000 - 0x945f9ffb SecurityFoundation ??? (???) <C4506287-1AE2-5380-675D-95B0291AA425> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x94606000 - 0x946e6fe7 com.apple.vImage 4.1 (4.1) <D029C515-08E1-93A6-3705-DD062A3A672C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x946e7000 - 0x946eaff7 libCGXType.A.dylib 545.0.0 (compatibility 64.0.0) <4D766435-EB76-C384-0127-1D20ACD74076> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x946eb000 - 0x94951ff7 com.apple.security 6.1.2 (55002) <64A20CEB-E614-D35F-7B9F-246BCB25BA23> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x949f3000 - 0x94a40feb com.apple.DirectoryService.PasswordServerFramework 6.1 (6.1) <00A1A83B-0E7D-D0F4-A643-8C5675C2BB21> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
0x94a41000 - 0x94b4dff7 libGLProgrammability.dylib ??? (???) <04D7E5C3-B0C3-054B-DF49-3B333DCDEE22> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x94b8e000 - 0x94cd1fef com.apple.QTKit 7.7 (1783) <0C6814E2-98C2-74F4-770F-BA355CA86F0F> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x94cf4000 - 0x94d08ffb com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <57DD5458-4F24-DA7D-0927-C3321A65D743> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x94d09000 - 0x94d5cff7 com.apple.HIServices 1.8.3 (???) <1D3C4587-6318-C339-BD0F-1988F246BE2E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x94d5d000 - 0x94da0ff7 com.apple.NavigationServices 3.5.4 (182) <8DC6FD4A-6C74-9C23-A4C3-715B44A8D28C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x94e13000 - 0x94e23ff7 com.apple.DSObjCWrappers.Framework 10.6 (134) <81A0B409-3906-A98F-CA9B-A49E75007495> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
0x94e24000 - 0x95613557 com.apple.CoreGraphics 1.545.0 (???) <1D9DC7A5-228B-42CB-7018-66F42C3A9BB3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x95624000 - 0x9567efe7 com.apple.CorePDF 1.4 (1.4) <78A1DDE1-1609-223C-A532-D282DC5E0CD0> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0x9567f000 - 0x95979fef com.apple.QuickTime 7.6.6 (1783) <1EC8DC5E-12E3-1DB8-1F7D-44C6EF193C58> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x95cb5000 - 0x95d0dfe7 com.apple.datadetectorscore 2.0 (80.7) <ADDE04FB-90A7-2132-75AF-C6B19DD0D97E> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x95d0e000 - 0x95d7cff7 com.apple.QuickLookUIFramework 2.3 (327.6) <74706A08-5399-24FE-00B2-4A702A6B83C1> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x95d7d000 - 0x95d9cfe3 libexpat.1.dylib 7.2.0 (compatibility 7.0.0) <82E6F83F-9667-2E39-1D9D-4A49C642527D> /usr/lib/libexpat.1.dylib
0x95ead000 - 0x95fdaffb com.apple.MediaToolbox 0.484.52 (484.52) <C9035045-D1B4-1B1F-7354-B00D1094D804> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x95fdb000 - 0x95fdbff7 com.apple.CoreServices 44 (44) <51CFA89A-33DB-90ED-26A8-67D461718A4A> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x960fe000 - 0x962c0feb com.apple.ImageIO.framework 3.0.4 (3.0.4) <027F55DF-7E4E-2310-1536-3F470CB8847B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x962fa000 - 0x967b5ff7 com.apple.VideoToolbox 0.484.52 (484.52) <F7CF9485-A932-1305-9AA6-3F7AC38B8B15> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x967b6000 - 0x967c3ff7 com.apple.NetFS 3.2.2 (3.2.2) <DDC9C397-C35F-8D7A-BB24-3D1B42FA5FAB> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x967c4000 - 0x967c5ff7 com.apple.audio.units.AudioUnit 1.6.7 (1.6.7) <838E1760-F7D9-3239-B3A8-20E25EFD1379> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x96838000 - 0x9683bffb com.apple.help 1.3.2 (41.1) <8AC20B01-4A3B-94BA-D8AF-E39034B97D8C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x9683c000 - 0x96877feb libFontRegistry.dylib ??? (???) <AD45365E-A3EA-62B8-A288-1E13DBA22B1B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x96a55000 - 0x96a7bffb com.apple.DictionaryServices 1.1.2 (1.1.2) <43E1D565-6E01-3681-F2E5-72AE4C3A097A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x96ac0000 - 0x96ac8ff7 com.apple.DisplayServicesFW 2.3.3 (289) <828084B0-9197-14DD-F66A-D634250A212E> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x96ac9000 - 0x96b44fff com.apple.AppleVAFramework 4.10.26 (4.10.26) <B293EC46-9F71-F448-F0E7-2960DC6DAEF7> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x96b45000 - 0x96b56ff7 com.apple.LangAnalysis 1.6.6 (1.6.6) <3036AD83-4F1D-1028-54EE-54165E562650> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x96b57000 - 0x96e7bfef com.apple.HIToolbox 1.6.5 (???) <21164164-41CE-61DE-C567-32E89755CB34> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x96e7c000 - 0x96e82fe7 com.apple.CommerceCore 1.0 (9.1) <521D067B-3BDA-D04E-E1FA-CFA526C87EB5> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
0x96e83000 - 0x96f77ff7 libiconv.2.dylib 7.0.0 (compatibility 7.0.0) <061ABF36-8BA9-79C1-6CE7-EC69A4998F51> /usr/lib/libiconv.2.dylib
0x96f78000 - 0x970fafe7 libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <D5980817-6D19-9636-51C3-E82BAE26776B> /usr/lib/libicucore.A.dylib
0x970fb000 - 0x9713dff7 libvDSP.dylib 268.0.1 (compatibility 1.0.0) <8A4721DE-25C4-C8AA-EA90-9DA7812E3EBA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x9713e000 - 0x97165ff7 com.apple.quartzfilters 1.6.0 (1.6.0) <879A3B93-87A6-88FE-305D-DF1EAED04756> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x97166000 - 0x97166ff7 com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <ABF97DA4-3BDF-6FFD-6239-B023CA1F7974> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x9717b000 - 0x97259fef com.apple.QuickTimeMPEG4.component 7.6.6 (1783) <FBD481B1-E8F8-4DA7-E33E-ACA5BFB0D90B> /System/Library/QuickTime/QuickTimeMPEG4.component/Contents/MacOS/QuickTimeMPEG4
0x9725a000 - 0x972d3ff7 com.apple.PDFKit 2.5.1 (2.5.1) <A068BF37-03E0-A231-2791-561C60C3ED2B> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x972d4000 - 0x97390fff com.apple.ColorSync 4.6.6 (4.6.6) <7CD8B191-039A-02C3-EA5E-4194EC59995B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x97391000 - 0x982e3ff7 com.apple.QuickTimeComponents.component 7.6.6 (1783) /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
0x982f4000 - 0x98302fe7 libz.1.dylib 1.2.3 (compatibility 1.0.0) <33C1B260-ED05-945D-FC33-EF56EC791E2E> /usr/lib/libz.1.dylib
0x98322000 - 0x98366fe7 com.apple.Metadata 10.6.3 (507.15) <460BEF23-B89F-6F4C-4940-45556C0671B5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x98367000 - 0x98372ff7 libCSync.A.dylib 545.0.0 (compatibility 64.0.0) <287DECA3-7821-32B6-724D-AE03A9A350F9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x983bc000 - 0x98436fff com.apple.audio.CoreAudio 3.2.6 (3.2.6) <156A532C-0B60-55B0-EE27-D02B82AA6217> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x98437000 - 0x98441ffb com.apple.speech.recognition.framework 3.11.1 (3.11.1) <7486003F-8FDB-BD6C-CB34-DE45315BD82C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x98442000 - 0x98452ff7 libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <C8744EA3-0AB7-CD03-E639-C4F2B910BE5D> /usr/lib/libsasl2.2.dylib
0x98544000 - 0x98548ff7 libGFXShared.dylib ??? (???) <801B2C2C-1692-475A-BAD6-99F85B6E7C25> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x98608000 - 0x98608ff7 com.apple.Carbon 150 (152) <8F767518-AD3C-5CA0-7613-674CD2B509C4> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x98609000 - 0x98647ff7 com.apple.QuickLookFramework 2.3 (327.6) <66955C29-0C99-D02C-DB18-4952AFB4E886> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x98745000 - 0x98745ff7 com.apple.Accelerate 1.6 (Accelerate 1.6) <3891A689-4F38-FACD-38B2-4BF937DE30CF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x98746000 - 0x9875afe7 libbsm.0.dylib ??? (???) <14CB053A-7C47-96DA-E415-0906BA1B78C9> /usr/lib/libbsm.0.dylib
0x9875b000 - 0x989ccfef com.apple.Foundation 6.6.7 (751.62) <5C995C7F-2EA9-50DC-9F2A-30237CDB31B1> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x989cd000 - 0x992b0ff7 com.apple.AppKit 6.6.8 (1038.36) <A353465E-CFC9-CB75-949D-786F6F7732F6> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x992bc000 - 0x993bdfe7 libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <C75F921C-F027-6372-A0A1-EDB8A6234331> /usr/lib/libxml2.2.dylib
0x993be000 - 0x99405ffb com.apple.CoreMediaIOServices 140.0 (1496) <DA152F1C-8EF4-4F5E-6D60-82B1DC72EF47> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/CoreMediaIOServices
0x99406000 - 0x9944bff7 com.apple.ImageCaptureCore 1.1 (1.1) <F54F284F-0B81-0AFA-CE47-FF797A6E05B0> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x9944c000 - 0x99489ff7 com.apple.CoreMedia 0.484.52 (484.52) <62B0C876-A931-372F-8947-7CBA0379F427> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/CoreMedia
0x9948a000 - 0x99497fe7 libbz2.1.0.dylib 1.0.5 (compatibility 1.0.0) <828CCEAB-F193-90F1-F48C-54E3C88B29BC> /usr/lib/libbz2.1.0.dylib
0x99498000 - 0x99613fe7 com.apple.CoreFoundation 6.6.5 (550.43) <10B8470A-88B7-FC74-1C2F-E5CBD966C051> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x99614000 - 0x99614ff7 com.apple.ApplicationServices 38 (38) <8012B504-3D83-BFBB-DA65-065E061CFE03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x9962b000 - 0x996c6fe7 com.apple.ApplicationServices.ATS 275.16 (???) <873C8B8A-B563-50F7-7628-524EE9E8DF0F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x997ce000 - 0x9987bfe7 libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <9F8413A6-736D-37D9-8EB3-7986D4699957> /usr/lib/libobjc.A.dylib
0x9987c000 - 0x998c2ff7 libauto.dylib ??? (???) <29422A70-87CF-10E2-CE59-FEE1234CFAAE> /usr/lib/libauto.dylib
0x998c3000 - 0x998c6fe7 libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
0x998d5000 - 0x999d7fe7 libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <015563C4-81E2-8C8A-82AC-31B38D904A42> /usr/lib/libcrypto.0.9.8.dylib
0x999d8000 - 0x99aa9fe3 ColorSyncDeprecated.dylib 4.6.0 (compatibility 1.0.0) <1C3E1CEF-6E88-4EAF-8A6E-4EC4C5642DDB> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
0x99b2e000 - 0x99b4dff7 com.apple.CoreVideo 1.6.2 (45.6) <EB53CAA4-5EE2-C356-A954-5775F7DDD493> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x99b70000 - 0x99d17ff7 libSystem.B.dylib 125.2.11 (compatibility 1.0.0) <2DCD13E3-1BD1-6F25-119A-3863A3848B90> /usr/lib/libSystem.B.dylib
0x99dcf000 - 0x99dd1ff7 com.apple.securityhi 4.0 (36638) <6118C361-61E7-B34E-93DB-1B88108F8F18> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x99dd2000 - 0x99e22ff7 com.apple.framework.familycontrols 2.0.2 (2020) <596ADD85-79F5-A613-537B-F83B6E19013C> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x99e23000 - 0x9a04eff3 com.apple.QuartzComposer 4.2 ({156.30}) <2C88F8C3-7181-6B1D-B278-E0EE3F33A2AF> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0xffff0000 - 0xffff1fff libSystem.B.dylib ??? (???) <2DCD13E3-1BD1-6F25-119A-3863A3848B90> /usr/lib/libSystem.B.dylib
OS Version: Mac OS X 10.6.8 (10K549)
Report Version: 6
Crashed Thread: 11
Thread 2:
Thread 3:
Thread 4:
Thread 5:
Thread 6:
Thread 8:
Thread 9:
Thread 10:
Thread 11 Crashed:
Thread 12:
Thread 13:
Thread 14:
Thread 15:
Thread 16:
Thread 17:
Thread 18:
cr2: 0x00000008
Binary Images:
geposted Mon 30 Apr 12 @ 2:21 am
THE ONE THAT CRASHED DURRING MY CLUB SET WHEN SELECTING THE CAM EFFECT.:::
Process: VirtualDJ Pro Full [171]
Parent Process: launchd [86]
Date/Time: 2012-04-27 23:13:09.802 -0700
Report Version: 6
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x00000000ff24086f
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Application Specific Information:
objc_msgSend() selector name: isEqual:
Thread 0 Crashed: Dispatch queue: com.apple.main-thread
0 libobjc.A.dylib 0x997d3f87 objc_msgSend + 23
1 com.apple.CoreFoundation 0x994a9f34 __CFDictionaryCallback + 420
2 com.apple.CoreFoundation 0x994aa2e9 ___CFBasicHashFindBucket1 + 537
3 com.apple.CoreFoundation 0x994b245c CFBasicHashFindBucket + 252
4 com.apple.CoreFoundation 0x994b2323 CFDictionaryGetValue + 131
5 com.apple.HIToolbox 0x96b616e1 TThemeTextCache::Create(void const*, THIThemeTextInfo const*) + 49
6 com.apple.HIToolbox 0x96b61646 ThemeTextCreate(void const*, THIThemeTextInfo const*) + 33
7 com.apple.HIToolbox 0x96b6123d DataEngine::GetTextDimensions(void const*, float, HIThemeTextInfo*, float*, float*, float*) + 279
8 com.apple.HIToolbox 0x96b610eb HIThemeGetTextDimensions + 188
9 com.apple.HIToolbox 0x96ca7603 HIStaticTextView::GetOptimalSizeSelf(CGSize*, float*) + 261
10 com.apple.HIToolbox 0x96ca6b3a HIStaticTextView::GetTextHeight() + 34
11 com.apple.HIToolbox 0x96ca6f2d HIStaticTextView::GetDataSelf(unsigned long, short, long, long*, void*) + 481
12 com.apple.HIToolbox 0x96b72323 HIView::EventHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 4453
13 com.apple.HIToolbox 0x96b5ec2f DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567
14 com.apple.HIToolbox 0x96b5def6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
15 com.apple.HIToolbox 0x96b5dd55 SendEventToEventTargetWithOptions + 58
16 com.apple.HIToolbox 0x96be98da SendControlDefGetData(HIView*, unsigned long, short, void*, long, long*) + 306
17 com.apple.HIToolbox 0x96be977c GetControlData + 76
18 com.apple.HIToolbox 0x96cfae8a AutoSizeDialog + 364
19 com.apple.HIToolbox 0x96d0473d CreateStdAlert(short, __CFString const*, __CFString const*, AlertStdCFStringAlertParamRec const*, bool, bool, unsigned long, OpaqueDialogPtr**, bool*) + 2958
20 com.apple.HIToolbox 0x96d05073 CreateStandardAlert + 99
21 com.yourcompany.SBDJ-Camera 0x0d137bbf MessageBox(char const*) + 88
22 com.yourcompany.SBDJ-Camera 0x0d137c67 CCamera::OnStart() + 127
23 ...roductions.virtualdjprofull 0x000e8952 CPluginVideoFx::Start() + 58
24 ...roductions.virtualdjprofull 0x000e6287 CPluginEngine::ActivateVideoFx(CPluginVideoFx*, int) + 109
25 ...roductions.virtualdjprofull 0x0003fdd0 CActionEngine::Execute(CAction2*, TActionParam*, unsigned long) + 100650
26 ...roductions.virtualdjprofull 0x00052cee CActionEngine::Do(CAction2*, TActionParam*, unsigned long) + 1204
27 ...roductions.virtualdjprofull 0x00107981 CButton::OnMouseDown(int, int, int) + 327
28 ...roductions.virtualdjprofull 0x000bae9f CMain::WndProc(void*, unsigned int, long, long) + 859
29 ...roductions.virtualdjprofull 0x0013a4fc MacToWindowEvent(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 861
30 com.apple.HIToolbox 0x96b5ec2f DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567
31 com.apple.HIToolbox 0x96b5def6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
32 com.apple.HIToolbox 0x96b807f3 SendEventToEventTarget + 52
33 com.apple.HIToolbox 0x96b9234f ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 1257
34 com.apple.HIToolbox 0x96b5f080 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2672
35 com.apple.HIToolbox 0x96b5def6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
36 com.apple.HIToolbox 0x96b807f3 SendEventToEventTarget + 52
37 com.apple.HIToolbox 0x96d09c17 ToolboxEventDispatcher + 86
38 com.apple.HIToolbox 0x96d09d4f RunApplicationEventLoop + 243
39 ...roductions.virtualdjprofull 0x0013aa0a main + 1226
40 ...roductions.virtualdjprofull 0x00024dfa start + 54
Thread 2:
Thread 3:
Thread 4:
Thread 5:
Thread 6: com.apple.CFSocket.private
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:
Thread 12:
Thread 13:
7 ...roductions.virtualdjprofull 0x00133df5 CVideo::Thread() + 43
8 ...roductions.virtualdjprofull 0x00123a69 IThread::ThreadProc() + 31
9 ...roductions.virtualdjprofull 0x00123ad8 StaticThreadProc(void*) + 17
10 ...ple.CoreServices.CarbonCore 0x932da54a PrivateMPEntryPoint + 68
11 libSystem.B.dylib 0x99b9e259 _pthread_start + 345
12 libSystem.B.dylib 0x99b9e0de thread_start + 34
Thread 14:
Thread 15:
Thread 16:
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x0828965c ebx: 0x994a5cf4 ecx: 0x991a7288 edx: 0xff24084f
edi: 0x0172a250 esi: 0x0828965c ebp: 0xbfffb8e8 esp: 0xbfffb898
ss: 0x0000001f efl: 0x00010206 eip: 0x997d3f87 cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
cr2: 0xff24086f
Binary Images:
0x24e0000 - 0x24e1fff com.apple.carbonbundletemplate 1.0 (1.0) /Users/anwaarhines/Documents/VirtualDJ/Plugins/SoundEffect/FlippinDouble.bundle/Contents/MacOS/FlippinDouble
0x24e5000 - 0x24e7fff +com.TexZK.VirtualDJSoundPlugin.Granular 1.0 (1.0) /Users/anwaarhines/Documents/VirtualDJ/Plugins/SoundEffect/Granular.bundle/Contents/MacOS/Granular
0x24eb000 - 0x24edfff +com.djcel.VirtualDJSoundPlugin.FlangerHQ 2.2 (2.2) /Users/anwaarhines/Documents/VirtualDJ/Plugins/SoundEffect/FlangerHQ.bundle/Contents/MacOS/FlangerHQ
0x24f1000 - 0x24f2fff com.apple.carbonbundletemplate 1.0 (1.0) /Users/anwaarhines/Documents/VirtualDJ/Plugins/SoundEffect/Cut.bundle/Contents/MacOS/Cut
0x24f6000 - 0x24f7fff com.apple.carbonbundletemplate 1.0 (1.0) /Users/anwaarhines/Documents/VirtualDJ/Plugins/SoundEffect/Flanger.bundle/Contents/MacOS/Flanger
0x2535000 - 0x2536ff7 ATSHI.dylib ??? (???) <8791C226-0725-314F-5897-BAAE57CA1EEE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/ATSHI.dylib
0x255f000 - 0x255fff7 libmx.A.dylib 315.0.0 (compatibility 1.0.0) <01401BF8-3FC7-19CF-ACCE-0F292BFD2F25> /usr/lib/libmx.A.dylib
0x2562000 - 0x2567fff com.apple.AppleMPEG2Codec 1.0.2 (220.1) <CE69C1D8-796C-753F-AD3C-F1CC2B8C0AAD> /Library/QuickTime/AppleMPEG2Codec.component/Contents/MacOS/AppleMPEG2Codec
0x2581000 - 0x25aafeb com.apple.mio.DAL.VDC_4 140.0 (1496) <B0C3DA44-D183-F32E-44DB-13D828580C5E> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Resources/VDC.plugin/Contents/MacOS/VDC
0x25ff000 - 0x2609ff7 com.apple.IOFWDVComponents 1.9.9 (1.9.9) <5B4E7BD7-EF5A-2F5C-DF8E-3D4A7B59F779> /System/Library/Components/IOFWDVComponents.component/Contents/MacOS/IOFWDVComponents
0x2782000 - 0x27befe3 com.apple.QuickTimeFireWireDV.component 7.6.6 (1783) <9D242689-A430-BD2D-3CF0-3AC6F6CCD1D9> /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacOS/QuickTimeFireWireDV
0x27ca000 - 0x27e5fef com.apple.AppleIntermediateCodec 1.3.2 (153) <D42634C1-8BDA-31ED-5216-13CB19BA7D1B> /Library/QuickTime/AppleIntermediateCodec.component/Contents/MacOS/AppleIntermediateCodec
0xd12c000 - 0xd419ffb +com.yourcompany.SBDJ-Camera 1.0 (1) <440FE60A-4776-259B-3903-E53F3DCD6E36> /Users/anwaarhines/Documents/VirtualDJ/Plugins/VideoEffect/SBDJ Camera.bundle/Contents/MacOS/SBDJ Camera
0x17aea000 - 0x17b3ffef com.apple.AppleProResDecoder 2.0 (223) <793BA98A-2E7D-1C39-998D-805B60034DF4> /System/Library/QuickTime/AppleProResDecoder.component/Contents/MacOS/AppleProResDecoder
0x17b77000 - 0x17bf1fef com.apple.AppleVAH264HW.component 2.0 (1.0) <4AF4C42D-7DE3-0C08-82A4-C3B970D3914E> /System/Library/QuickTime/AppleVAH264HW.component/Contents/MacOS/AppleVAH264HW
0x17cb4000 - 0x17ccdfe7 com.apple.applepixletvideo 1.2.19 (1.2d19) <4A68731C-8071-6CF5-012C-40F00CD1333A> /System/Library/QuickTime/ApplePixletVideo.component/Contents/MacOS/ApplePixletVideo
0x1a6f8000 - 0x1a6f9ff3 +com.djcel.VirtualDJVideoPlugin.Cinemascope 1.0 (1.0) /Users/anwaarhines/Documents/VirtualDJ/Plugins/VideoEffect/Cinemascope.bundle/Contents/MacOS/Cinemascope
0x1aa00000 - 0x1aa06ff7 com.apple.audio.AppleHDAHALPlugIn 2.0.5 (2.0.5f14) <38E3C1A4-84E4-C105-B55F-8FC4C154036D> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x1afaf000 - 0x1afb0ff7 com.apple.textencoding.unicode 2.3 (2.3) <78A61FD5-70EE-19EA-48D4-3481C640B70D> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
0x1afb5000 - 0x1afb9ff7 com.apple.CommonCocoaPanels 4.0 (16) <30D57C5A-2C5E-3A3E-A9D8-F5E968322AD6> /System/Library/CoreServices/CommonCocoaPanels.bundle/Contents/MacOS/CommonCocoaPanels
0x1b767000 - 0x1b791ffb com.apple.QuickTimeIIDCDigitizer 7.6.6 (1783) <8608D7B6-2D9C-5DEF-DDC8-FE630A598888> /System/Library/QuickTime/QuickTimeIIDCDigitizer.component/Contents/MacOS/QuickTimeIIDCDigitizer
0x1c612000 - 0x1c61bfff +com.yourcompany.SBDJ_Strips ??? (1.0) <222EF553-3EF2-2D11-3CE3-098B9BE344F8> /Users/anwaarhines/Documents/VirtualDJ/Plugins/VideoTransition/SBDJ Strips.bundle/Contents/MacOS/SBDJ Strips
0x1c622000 - 0x1c625fff +com.atomixprod.beatgrid 1.0 (1.0) /Users/anwaarhines/Documents/VirtualDJ/Plugins/SoundEffect/BeatGrid.bundle/Contents/MacOS/BeatGrid
0x1e7b3000 - 0x1e7f4fe3 com.apple.audio.SoundManager.Components 3.9.4 (3.9.4) <AD66647C-03A9-EBAF-6FFC-E5A631F4D6BE> /System/Library/Components/SoundManagerComponents.component/Contents/MacOS/SoundManagerComponents
0x1ebf0000 - 0x1edd6fef com.apple.audio.codecs.Components 2.0.3 (2.0.3) <8DA1B494-CD97-D4CC-3D5D-FACFAAE9D968> /System/Library/Components/AudioCodecs.component/Contents/MacOS/AudioCodecs
0x1f630000 - 0x1f64dff7 com.apple.IOFireWireLib 4.2.6 (4.2.6) <D1D1F91F-2A48-8B86-1CB2-EC849BDB9808> /System/Library/Extensions/IOFireWireFamily.kext/Contents/PlugIns/IOFireWireLib.plugin/Contents/MacOS/IOFireWireLib
0x222e0000 - 0x22459ff7 GLEngine ??? (???) <64C74F67-44B5-7DEF-CCA6-C8A9FF9BB60A> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
0x2248b000 - 0x22890fe7 libclh.dylib 3.1.1 C (3.1.1) <15AD52DD-FC3F-305E-5C31-699329E8FDE1> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib
0x228b4000 - 0x228d8fe7 GLRendererFloat ??? (???) <AD081A9B-1424-1F17-3C68-9803EBA37E8D> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFloat
0x23067000 - 0x230a3ff3 com.apple.DP.ScreenInputDevice 15.0 (15.0) <423039F0-E590-0254-D767-C04F1E2287AA> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Resources/AppleScreenInputDevice.plugin/Contents/MacOS/AppleScreenInputDevice
0x2515d000 - 0x25190ff3 com.apple.FWAVC 130.46 (46) <2F2CD20F-5B9E-911A-7EA8-40D016A6C23C> /System/Library/PrivateFrameworks/FWAVC.framework/Versions/A/FWAVC
0x25634000 - 0x257e2fe3 com.apple.TundraUnits 140.0 (1496) <51A20C84-A2F6-4F40-2E33-D5AB9E0CE068> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Resources/TundraUnits.bundle/Contents/MacOS/TundraUnits
Report Version: 6
Thread 2:
Thread 3:
Thread 4:
Thread 5:
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:
Thread 12:
Thread 13:
Thread 14:
Thread 15:
Thread 16:
cr2: 0xff24086f
Binary Images:
geposted Mon 30 Apr 12 @ 2:23 am
lightningfb wrote :
No theres no way to select what cam to use with the plugin.. The plugin for PC you can but the one for Mac you cannot. You can only change size etc. On Mac I have to go to Photobooth and make the systems default cam being the webcam as apposed to the isight built in cam that faces me.
There is a camera ID slider...
geposted Mon 30 Apr 12 @ 6:22 am
Crash Report 1: No mention of my plugin at all in the report
Crash Report 2: I'll have a look at that one
Crash Report 3: You activated the plugin and it popped up a message box - any idea what the message in that box was?
In any case I've obviously missed a potential error condition in the OnStart() function so I will check that out later today.
Regards,
Scott
Regards,
Scott
geposted Mon 30 Apr 12 @ 6:25 am
Camera plugin updated to v1.11.
I've added some additional error checking, so we shall see if that helps with your issue. I still maintain that you can use the Camera ID slider - I've just tested it on my laptop with two webcams hooked up and was able to switch between sources.
A couple of other changes for this version:
* Streamlined startup code, plugin is marginally quicker to start
* Changed texture interpolation for a faster method with less CPU usage
* Changed fixed target texture size to a dynamically calculated one
geposted Mon 30 Apr 12 @ 2:03 pm
Wow! You are the MAN! Very fast to address issues! Thank you so much. We appreciate you very much. Ill give it a try now :)
geposted Mon 30 Apr 12 @ 3:09 pm
Any better for you lightningfb?
geposted Tue 01 May 12 @ 1:43 pm
andresdj_mix_ wrote :
Dear sorry you can not explain it because I do not speak English, I download the latest version of the plugin showlogo mac, but when you install this plugin and open vdj I have no problems, it is only when I run the plugin showlogo automatically stops the mix vdj videos, pictures can not melt, ie all the effects that have images fade the crossfader is acting as a simple cut, and to merge virtual dj video again
To confirm, these steps in this order:
Open VDJ
Activate ShowLogo
Load video on deck 1
Load video on deck 2
Crossfade between the video decks is then broken?
I've been completely unable to replicate this I'm afraid.
geposted Tue 01 May 12 @ 1:45 pm
Yes! Much better. Thank you for the quick update. Not one crash last night. Runs much smoother,, still a little high on the CPU meeter but that may just be a RAM issue as I'm on rumning 2Gs.. Ill upgrade to 4 and see if that helps. I understand that the cam plugin is a heavy effect but its definitely much more smooth! When my vids became choppy I just turned off the cam and everything was fine. Thanks again SBDJ :-)
geposted Tue 01 May 12 @ 1:58 pm
sbdj anyway we can get a camera rework for windows with a resizable option like you did for mac????
geposted Tue 01 May 12 @ 8:43 pm
