Hi,
Recently ever time I try and record a mix the above error message comes up. I have had a look online and there doesnt seem be any clear answers as to how to fix the issue on a Mac.
Any help is appreciated,
Thanks,
Seth
Thanks,
Seth
geposted Wed 25 Jan 12 @ 5:42 pm
Have you changed the Filepath (provide the path and name of the file where the recording is going to be saved)?
Have you tried it with MP3?
geposted Thu 26 Jan 12 @ 7:57 am
please help the same exact thing happens to me!
geposted Thu 26 Jan 12 @ 8:28 pm
Hi,
Fiddling around with the file path eventually made it work. For some reason it wouldn't save to certain file paths. Odd.
Thanks for the help
Thanks for the help
geposted Fri 27 Jan 12 @ 3:36 am
Hi i need help too. mine says cant open //untitled.mp3. or /untitled.mp3. i also tried with .wav
geposted Thu 14 Jun 12 @ 5:09 pm
The answer is simple above!
geposted Fri 15 Jun 12 @ 8:51 am
In vdj le i can record mix only in vdj installation directory, c:/program files/ vdj. Try to do it
geposted Wed 20 Mar 13 @ 11:37 pm
On mac you have to save in the VDJ le folder, default location is in documents!
geposted Fri 24 May 13 @ 7:48 am
NOTHING WORKS
geposted Fri 28 Mar 14 @ 5:36 pm
Above the START RECODING button, you'll see "CONFIG...", click it and press "Browse" and locate the filepath. it worked for me with this.
geposted Fri 19 Sep 14 @ 7:29 am
my sound no conct
geposted Thu 01 Sep 16 @ 8:27 pm
