So I run primarily music videos now, but when I load up an mp4 or an mpeg video the video is really jumpy and not on time.
The only way I've figured around this is to convert the files to .avi and they play fine, except that I have over 5,000 music videos and that is going to take forever. I'm running a baseline 13" mbp, so it's nothing fancy, but this happens no matter what kind of video input i'm plugging into, whether it's a projector or into a TV composite.
Any help would be great!!!
Thanks!
Thanks!
geposted Sat 28 Jan 12 @ 5:58 am
Guess the problem is the Mac videocard.
As far as i know, there is from VDJ point of view, no way to solve this problem.
Maybe one of the next VDJ version, can deal with this kind of lower videocards.
geposted Wed 01 Feb 12 @ 4:20 am
I messed with some of the video options, something to do with the khz, i'm not going to open the program right now to check my settings, but i believe it's fixed.
geposted Wed 15 Feb 12 @ 11:53 am
How did u fix this I got same problem
geposted Tue 28 Feb 12 @ 6:07 pm
Go to performances in Setup and change the 48khz conversion to "Fast Sampling"
Also check "Decode while Hidden" in the Video options.
geposted Fri 02 Mar 12 @ 2:39 am
Uncheck the hardware accelerator in the video tab in config, that seems to have done the trick for me
geposted Sun 06 Jan 13 @ 10:59 am
Disable Hardware Acceleration. Worked for me. It is very annoying that lag.
geposted Sat 10 Aug 13 @ 1:17 pm
Sorry guys but the answers you are gaving are for windows, mac version dont have that settings on the video tab
geposted Sun 18 Aug 13 @ 5:58 pm
i just convert to MOV format and that takes care of that
geposted Tue 29 Oct 13 @ 7:39 pm
my friend just convert the videos to MOV format and it works for him
geposted Tue 29 Oct 13 @ 7:41 pm
None of these worked. I am running a dell computer with a vizio tv but nothing will fix the lag on the external screen. When i uncheck the hardware acceleration, the video disappears on the tv. Is there anything I can do to fix this?
geposted Tue 28 Jan 14 @ 12:49 pm
I'm sorry but this is the Mac version forum!
Please be so kind and open a topic at PC Technical Forum or create a ticket on support side.
https://virtualdj.com/forums/20/PC_Version_Technical_Support.html
geposted Fri 31 Jan 14 @ 2:07 am
