Forum: Old versions
Topic: VMS4 4 decks mode
Hi all , i got some problems with the VMS4 . i'm using 4-deck mode , however i can't hear anything from deck 3 and 4 , i configured evrything
INPUTS - NONE
OUTPUTS - External Mixer - Left Deck 1&2 , Right Deck 3&4
SOUND CARD - ASIO DRIVER -
8 in 2 out
Midilog 1 - Out 1 Out 2
Midilog 2 - Out 3 Out 4
Midilog 3 - Out 5 Out 6
Midilog 4 - Out 7 Out 8
Master Rec Disabled Disabled
Can anyone help me ?
geposted Tue 07 Feb 12 @ 1:49 am
have you set the settings right on the front of your VMS? all channels to usb and 8 out instead of 4 out?
yes i did , soundcard were set to 8 , and usb .
I can't hear decks 3 and 4 either. I'm using vdj 7.4.6 le. I can adjust the controls to work. Just can't get decks 3 and 4 to play any sound. Decks 1 and 2 are fine.
Is there a solution?
2 things i can think of..
1. You have set the unit to 8out mode but you havent power cycled the unit. So be sure its set to 8out mode , power off, power on and try again.
2. You are running VirtualDJ using a 2 Decks skin (even though the standard LE skin for this unit should be a 4 decks one)
Try to install 7.4 LE (4 decks) from your Account to make sure the skin is installed and then install 7.4.6 over that.
