Forum: VirtualDJ Plugins
Topic: clipbank / still images
Hi folks,
Is there any way of loading still images (bmp/jpg etc) into the clipbank? Looking for a way of flashing up promos, flyers etc for the venue I work in. The slideshow's no good to me for this, as I need to be able to select a particular image, in much the same way that the video clipbank operates. Any thoughts?
Cheers,
John
geposted Tue 14 Feb 12 @ 2:17 am
You should be able to achieve that with the Firetext plugin, other than that you will have to make each image into a small video file to run it in clipbank.
Clipbank supports still images, I've just testing with a JPEG to double check.
Bugger, I tried an image in clipbank before posting and wouldn't play on my desk top... I'll check on my gig lappy.
EDIT
Yep, loads images in gig lappy just fine, sorry about the misinformation.
djsherz wrote :
Hi folks,
Cheers,
John
Sure! simply make a video on a editor that allows photo inserts.make one video clip for each photo,flyer whatever and load new photo/vids on clipbanks...why u guys have to make everything so complicated?....he,he
Thanks for the suggestions folks! Tried loading images into the clipbank on a couple of machines, didn't work on either. Turns out it's pretty easy to load the jpegs into Windows Movie Maker and turn them into a short video clip though, works great that way!
