Hi all,
I'm looking for the solution/plugin to get playlist from the internet. Is there such a plugin at all? Or I have to do it by myself?
I'd like to enqueue next song from the specific URL. That plugin should check that URL periodically and update current playlist dynamically with no user interacion. Is there any?
Is it possible to do it with plugin SDK? If so - where could I find the documentation for SDK? Or download it? Only what I could find was brief information on http://www.virtualdj.com/wiki/Developers.html site, with some samples.
thanks for the info
regards
mqqla
thanks for the info
regards
mqqla
geposted Fri 17 Feb 12 @ 10:15 am
The next release of Essential Media which is about ready but not up yet allows you to play videos or mms streams from the internet.
It doesn't check some playlist though.
geposted Fri 17 Feb 12 @ 12:45 pm
