The right click context menu on the playlist (repeat, mix now, remove)
how about adding the following to the mix now part, mix cut, mix fade and mix tempo to allow more freedom with mixing when you have to use playlists, or to allow the mix cut, fade, tempo to be set per individual track.
geposted Fri 24 Feb 12 @ 9:24 am
