Greetings, I just bought the numark N4 GREAT hardware and I tried it with OTHER SOFTWARE and is very COOL program but I've always used is Virtual Dj , and I can not get it to work someone has a video or manual or know how to configure the N4 with virtual dj I thank you very much. get to hear but the buttons do nothing do nothing dishes not to do.
geposted Fri 02 Mar 12 @ 11:38 am
Most likely you are using an out-of-date version of the software that does not support the Numark N4.
The Numark N4 is natively supported in the latest VirtualDJ Pro v7.0.5b: https://virtualdj.com/wiki/VirtualDJ%20Controllers.html
To use the N4 or any other MIDI controller, you will need to purchase the full VirtualDJ Pro: https://virtualdj.com/buy/
Or if you have already purchased, you will need to upgrade to the latest version: Register your Pro serial number on the page https://virtualdj.com/users/edit.html and then download the latest version from the Download Center: https://virtualdj.com/download/updates.html
geposted Fri 02 Mar 12 @ 12:08 pm
thanks, i will try it. really thanks
geposted Fri 02 Mar 12 @ 12:51 pm
can anybody tell me how can i adjust the loop settings on my numark n4 to loop more than 8 bars i would really be happy with 16 :)
geposted Sun 24 Nov 13 @ 5:58 am
