Better sound when you play the same song together/The sound quality is very poor
geposted Tue 20 Mar 12 @ 9:59 pm
The sound quality of VDJ has been RTAd and is on a par with Traktor.
Your problem lies elsewhere.
geposted Tue 20 Mar 12 @ 10:03 pm
It's probably because the music is phazing just like a phazer or flanger effect, the only difference is the effect has an lfo that changes the distance between the two audio sources for the classic jet effect... I think it has something to do with the sound from both tracks canceling one another.
geposted Tue 20 Mar 12 @ 10:56 pm
in the new vdj 8, be patient!!!
geposted Wed 21 Mar 12 @ 2:15 pm
Ok.
geposted Sat 24 Mar 12 @ 1:28 pm
A switch/tap to make BALANCE Stereo Or un-balance Mono ( In/Out Phase ) Output.
I use the right side on Ch 1 & 3 and it sound Ok.
geposted Sat 24 Mar 12 @ 6:52 pm
This is already available in the advance sound config setup of the VDJ there is an option thick mark for you to choose how do you want your output "MONO or STEREO". Just to recap even in the $100,000 worth of high end digital mixer theres no option to tap a button on front panel to convert the whole thing to stereo or to mono it must be done usually in output signal as an options.
geposted Wed 28 Mar 12 @ 6:57 pm
