hi im new to using the essential visuals plugin
but im having a small problem, i am using it currently to display two panels , one with some moving text, and another with a Gif Logo of mine,
but as soon as i play a music video only the first panel is visible , the other panel dissapears
presumably its like a layer system and the video is "in front" of it, but i cannot find any way to bring the logo back since the "move to top" option is grayed out which suggest that its already at the top..
any ideas?
any ideas?
geposted Sun 01 Apr 12 @ 4:40 pm
Hi
Try play first video and than enable effects.
Regards Tomas
Regards Tomas
geposted Tue 03 Apr 12 @ 1:22 am
I tried it and the images still disappear a song or so later
Just to clarify
Even if I am running a panel with moving text on it
And that panel also has a jpeg or a gif in it
The text remains but the image disappears
I dont understand this....... :(
geposted Tue 03 Apr 12 @ 3:59 am
Matty, I sent you a PM with my email address so please email me so I can help you with your problem.
geposted Tue 03 Apr 12 @ 4:52 pm
