Forum: Old versions
Topic: Vestax Typhoon Problems
I have Virtual DJ 7 along with a Vestax Typhoon. Whenever I press the filter button, the track (and all tracks thereafter) will stop whenever I turn off the filter. They will only play when the filter button is turned back on. I haven't changed any of the mappings, so what can I do in order to turn the filter on and off while keeping the track going?
geposted Tue 10 Apr 12 @ 4:04 pm
I have the exact same problem but I have virtual dj LE
Please register your VirtualDJ LE serial number to your profile and then download the most recent version of VirtualDJ LE from your Download Center: https://virtualdj.com/download/updates.html
If this doesn't help, then perform a clean re-installation of the software: https://virtualdj.com/wiki/How%20do%20I%20perform%20a%20clean%20re-installation%20of%20the%20software.html
NOTE: The user above was probably experiencing issues due to using an out-of-date and possibly illegal version of VirtualDJ Pro that doesn't have the correct mappings.
I have problem with monitoring botton. for example,WHen I use headphone to try to mix music, if I push deck 2 monitoring Botton but deck 1 sound comes out. so I can't listen only one side of sound. I already download and use latest software but it didnt fix. what can I do with this problem?? Please give me an answer!!
Please check that it's configured correctly:
https://virtualdj.com/wiki/Typhoon.html
Also, check the position of the headphone mix knob on the skin. This determines how much of the master output vs the deck that you have selected for PFL is heard in your headphones.
Hi there. I've got another problem. I use mini PC (HP mini). I download all the latest soft wear and using virtual DJ LE. when I connect to DJ controller, I can drag a music to deck 1 or 2 but I cant play. But when I disconnect PC and DJ controller, I can play music. How could I solve this problem? please give me an answer. thanks
If the song doesn't play (PLAY button lights up, but the song doesn't start moving), then it means that the sound card settings are incorrect, or possibly there is an issue with the Typhoon ASIO driver. Please see https://virtualdj.com/wiki/Typhoon.html
NOTE: WIthout the Typhoon connected it will just use the computer's built-in sound card for a basic output.
I have the same problem as the first two posters.
If I stop a track with the filter turned on on the right deck the play button only works with the filter turned on.
I tried downloading the latest installation (I'm also using LE) but that seems to be exactly the same as the version supplied (i bought my Typhoon 2 days ago)
I also did a full clean install following your instructions carefully... TWICE... still the same problem..
I hadn't planned on using the filter much anyway but the play button freezing like that would be a major problem if it happened live..
Please can you fix this bug as otherwise I may have to return the controller and software (I don't want to risk this happening live)
Thanks
Anton
Note: By the way I found the assumption that the OP was using a hacked copy and that it wasn't a software bug a little unnecessary and a little patronizing.. Not the best first impression for customer support.
I have a problem with the vestax typhoon, when I bought it the first time the dishes were turning blue when touched and became red and when they occupy for a few times the dishes were put permanent red and can not move the plates as before I can only move when they are paused, what can I do?
and when I move the plates increases or decreases the speed of sound
having the same problem as the author of this topic. no answer here helped the situation.. does anyone knows how to handle it?
I have the same problem! Does anybody know how to fix this? It's starting to stress me out, because the controller doesn't seem to know the difference between a play button and a filter
same problem
remori wrote :
same problem
....as who? There's more than one problem posted in this thread. Be specific.
