I'm planning on buying the new(ish) mixer but was wondering if anyone knows if the Pioneer DJM-T1 was compatible with VDJ.
I'm not much a fan of Traktor (which comes with the mixer), I simply tolerate it for my house, dub step etc...but have yet to mess around with dnb, drum step and hard style with its. It's not the a beat grid I'm used to, so would much rather stick to VDJ.
If it's compatible, would it simply be plug-and-play, or would I have to map it/configure everything?
geposted Fri 27 Apr 12 @ 3:31 am
none of the pioneer djm series have native support from atomix unfortunately as native instruments demand exclusivity to support equipment in traktor scratch pro, so you will have to define and map it yourself to get use of the midi controls, but it's fairly easy and you can get help on the forum if you have any difficulties.
geposted Fri 27 Apr 12 @ 3:49 am
The DDJ-ERGO and DDJ-S1 are natively supported in the latest version: https://virtualdj.com/wiki/VirtualDJ%20Controllers.html
There is a user-made mapper for the DDJ-T1: https://virtualdj.com/addons/13754/DDJ-T1_Mapper.html
geposted Fri 27 Apr 12 @ 2:54 pm
Been thinking of getting that DJM-T1 also, can I use the soundcard with VDJ or is that locked as Well??
Thanks for the info and time
Huey
Huey
geposted Tue 26 Jun 12 @ 1:55 pm
Can I use the soundcard with VDJ?? That's a lot of money to throw out on a chance it might not work......
geposted Wed 27 Jun 12 @ 9:03 am
geposted Wed 27 Jun 12 @ 2:18 pm
muy buenas noches, el motivo de escribir en el foro es que no he podido hacer andar el mapper ( https://virtualdj.com/addons/15728/Pioneer_DJM-T1.html ) para mac. a mi me da un error al instalar la ap.
si alguien me puede ayudar lo agradeceria mucho
Saludos
Saludos
geposted Tue 22 Sep 15 @ 2:45 am
Good evening , De Post Reason In what forum is not able to do walk the allocator ( https://virtualdj.com/addons/15728/Pioneer_DJM-T1.html ) for mac . it gives me an error when installing the app.
if anyone can help me I would greatly appreciate
Cheers
Cheers
geposted Tue 22 Sep 15 @ 3:44 am
Have you installed the propre Mac drivers?? Mine works fine on my MacBook.
geposted Wed 23 Sep 15 @ 4:14 am
if , and install the driver that comes vercion 1.1 for Mac. But still take the mapper . if you already did walk, you tell me what steps performed ? maybe it's my mistake . From already thank you very much.
geposted Thu 24 Sep 15 @ 12:01 am
can someone pass me the djm-t1 add on or tell me how to map it manually
geposted Thu 01 Oct 15 @ 1:36 pm
You dont need any add-on or map it. Pioneer DJM-T1 is natively supported in VirtualDJ 8. https://virtualdj.com/wiki/VirtualDJ8%20Controllers.html
geposted Thu 01 Oct 15 @ 2:01 pm
