Forum: VirtualDJ Skins
Topic: Attn all Skinners
Please will you unify and use the same icons that show what file type. I really hate the ones that have the tiny K, V & L's. they are hard to read and distinguish between each other. the proper way SHOULD be the Green Speaker for Audio, BLUE Mic for Karaoke and white FILMSTRIP for VIDEO. Thank you for your consideration
geposted Sat 28 Apr 12 @ 3:50 pm
have you got any examples? I'm making a skin currently and could include them if they look good.
Maybe you think about something like this, eh?
(took from famous skin grom by DJDad)
yep, but I meant the actual icons... I had the same though the other day but google didn't get me the inspiration I was after. The icons are meant to be 16 x 16 pixels but that shouldnt matter as resize in photoshop is pretty good, so probably after 64 x 64 pixels that way I can just make them 25% of the original and they should look pretty good.
well,
I would be glad, if this function would be better explainend & documentated. What icon is for what?
Most of them I know, but some of them = ?!?
Or is it possible to get an icon-block of the original, so we just change the browser-icons?
Greets
Music234
I have created a new wiki page Tips for Skinners https://virtualdj.com/wiki/
Started with icons, but will include other tips and tricks soon. Of course you may contribute with your knowledges (thats what wiki is for :) )
....mmmh, you posted the right link?!
BTW:
One of the most important for me is the fact, that he X/Y coordinates can be "calculated" in the xml
<button action="action">
<size width="ww" height="hh"/>
<pos x="1403" y="6"/>
<selected x="+0" y="+1500"/>
<down x="+0" y="+1500"/>
<over x="+0" y="+900"/>
</button>
..never read this in the wiki, but imO very important to know
;o)
music234
EDIT:
I found it, sorry for the question about the right link!
That is the entire point about skining. So each user can create the skin to look, and feel, the way they choose. Not the manufacturer. To standardize the icons would be counter intuitive to the thought process....
thanks for making that bob, but do you think it's possible to give an explination about what each icon is, so we know what we are replacing.
I made this page https://virtualdj.com/wiki/Default%20Icons.html
About the missing ones... never seen them to be honest. If someone knows let me know. Some could be reserved for future use (D6,D7,D8) and some could be created in earlier versions. I will update the page as soon as i find out about them.
Thank you for this needed information.
;o)
Bob,
If memory serves me right (and it doesn't alway). D6,7,8 and old icons that were relate to when Napster was integrated!!?? Pretty sure they are not used now, as new icons on line E were created for Netsearch!!
yES< DJDAD"s Icons are the best ones in my opinion
if you dont like custom icons dont mention it in the browser skin
like
<browser>
<size width="1368" height="242"/>
<pos x="0" y="535"/>
<text font="Lucida Sans" size="14" color="#FFFFFF" selected="#352605" stripes="#181818"/>
<options font="Tahoma" size="12" color="#FFFFFF" over="#99DDFF"/>
<widgets font="Virtual DJ" size="10" color="#606060"
facecolor="transparent"
lightcolor="#808080"
shadowcolor="#606060"
darkshadowcolor="transparent"
highlightcolor="transparent"
trackcolor1="transparent"
trackcolor2="transparent"/>
<icons x="204" y="773"/>
<customicons x="4" y="773"/>
<custombuttons x="392" y="773"/>
<colormatrix rr="100" gr="100" br="100" rg="100" gg="100" bg="100" rb="100" gb="100" bb="100"/>
</browser>
just delete the icons/customicons/custombuttons line in that browser section
<browser>
</browser>
in this case if you dont mention it by default it loads default icons
peace
Dj Pradeep
