I've created a Mapping for the Pioneer DJM 850: http://www.virtualdj.com/addons/14604/Pioneer_DJM-850.html
If you want me to add more Features, then just tell me which faders and knobs i should add. :)
(I'm sorry but i can't write in english perfectly, because it it's not my native language.)
geposted Mon 07 May 12 @ 2:18 am
If possible can you get the gains to map? I can map deck 1 but when I deck 2 it moves deck one. Can you help me with this?
geposted Sun 27 Jan 13 @ 10:52 am
Try adding deck 1 or deck 2 appropriately in front of the mapping, e.g: deck 2 eq_low - This will make it apply to the specified deck.
Also, please see http://www.virtualdj.com/wiki/MIDI%20mapping%20an%20external%20DJ%20mixer.html
geposted Sun 27 Jan 13 @ 10:58 am
you shouldn't map the gains because you'll have some kind of "double gaining" which will result in a creepy distorted sound.
geposted Sun 27 Jan 13 @ 12:29 pm
The only issue that i have is when i take my hand off the platter there is a slight delay. Is there a way to fix it?
geposted Fri 12 Apr 13 @ 12:59 am
First of all that issue has nothing to do with my mapping for the djm850 ;)
I guess to your question answer is no - that's absolutely normal.
geposted Fri 12 Apr 13 @ 3:05 am
I have to say I've been a big fan of virtual until now. I bought a djm 850 and cdj 850's. Its been a total pain. Volume issues is the biggest problem along with lag. If anyone can help it would be nice. I'm at the point onf switching to serato to which i'm not thrilled about doing.
I guess I need help with all the settings.
geposted Sat 11 May 13 @ 11:49 am
